Share
 Aero Wiper Blades
Go to page : Previous  1, 2, 3, 4  Next
Richard
Richard
Aero Wiper Blades - Page 2 Empty
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed Oct 19, 2011 8:39 am
Very Happy
Lady J
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed Oct 19, 2011 6:54 pm
Thank you, all ordered!
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyTue May 08, 2012 10:49 pm
I've just bought a GOODYEAR set from Costco normaly £6.95 down to £3.46 a blade offer ends 20th of May. Mind you need to buy a Costco card to begin with but if you've got one already then all the better.
Aero Wiper Blades - Page 2 08052012202
Before
Aero Wiper Blades - Page 2 08052012196
After
Aero Wiper Blades - Page 2 08052012198
Aero Wiper Blades - Page 2 08052012200
Aero Wiper Blades - Page 2 08052012201
Mind you the offside one still doesn't touch the screen on the outside when parked but neither did the original, tested stationary and looking good. Will need to put Phileas back together to test on the open road Rolling Eyes
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 12:22 am
Good stuff ST - I just ordered a set from wiperblades.co.uk - £18 delivered methinks.
You ought to spin that spare wheel carrier so that the clip is at the bottom - that way any water that collects inside will drain out below rather than staying inside the cover and festering.
Aero Wiper Blades - Page 2 Melogo11
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 7:00 pm
Good point about spare wheel carrier, I have just began to notice everyone has there's at the bottom. It needs trimmed anyway to fit my spare alloy they are not meant to overlap like that also. The fittings will need moved aswell I suspect and the disc cut. Only another 1000 jobs to complete before the Sleepover Crying or Very sad
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 7:57 pm
What ref number did you order? Couldn't see our model in the list
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 9:24 pm
They haven't arrived yet olive. Rest assured once I confirm they fit correctly I'll post the details. I don't want folks reading this ordering stuff that may not fit.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 9:29 pm
Measure the ones on yours a get the same size as that. I'd do it but it's cold and raining outside. Very Happy
Aero Wiper Blades - Page 2 Img_4810
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 09, 2012 9:33 pm
It's 16" or 410mm thats what i've got.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyThu May 10, 2012 5:04 pm
Update: the blades I ordered from wiperblades.co.uk DO NOT FIT.
I've emailed them photos of the original fitment to see if they have something compatible.
Skytiger: do you happen to know the description of the fitting you used? Did the pack contain various options? Is there a code on the one you used?
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyThu May 10, 2012 7:22 pm
Don't know how but I had saved in my favorites a link To the page and the ref was WB-4-16 Bayonet fitting flat wiper blade, is this what you ordered Tim?
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyThu May 10, 2012 7:59 pm
The description was for a Bayonet Arm
Yes for Hook arm and Bayonet Arm
The code for the fitting was A-5B it can just be seen in my "After" pic but not sure if this is GOODYEAR's code or a universally used one.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyThu May 10, 2012 8:10 pm
olive - yes that's the one - they don't fit.
ST: thank you.
I'll see if wiperblades.co.uk can come up with something. Failing that I'll hunt down some Goodyears.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyFri May 11, 2012 8:55 pm
Ooh be careful - wiper arms on Classic Bays are different to those found on a BraziBay.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptySun May 20, 2012 8:22 am
Have you managed to sort this one out?
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptySun May 20, 2012 8:45 am
Wiperblades.co.uk cannot supply an aero blade with the correct fitting.
I suggest trying to source the same 16" Goodyear blades Skytiger bought from Costco.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptySun May 20, 2012 6:22 pm
There you go then ... not as cheap as Skytiger was able to get them, unless you have a Costco card. Maybe this entrepreneurial ebayer does! You'll need 2 and 16" in length.
Goodyear wiper blades via eBay.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptySun May 20, 2012 7:50 pm
Or, now I've been doing some housekeeping and joined up some topics, based on pastymaster's success with his order I've now ordered these:
16/16 Aero Blades
Will see how they go .....
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptySun May 20, 2012 11:18 pm
The offer price at Costco finished today and you were only allowed a max purchase of ten which I used up with my cars, family and friends.
They will still be available at the £6.95 a blade if anyone wants a pair I could bring them to the Kombi Sleepover.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyTue May 22, 2012 4:50 pm
The new Aero Wiper Blades I ordered from the same place as pastymaster via Ebay turned up today. Here's how I fitted them:
Aero Wiper Blades - Page 2 Img_1411
The fitting on our Kombis is known as 'bayonet' - essentially there's a little spigot on the wiper arm and underneath it is a similarly shaped hole. The fitting on the blade has a hole that the spigot locks into and then underneath a small sprung lever that locks into the hole on the wiper arm.
Old wiper blades removed, the fit into the new blades was very tight, so I elected to take off the wiper arms, fit the blades and then put the arms back on my Kombi.
Aero Wiper Blades - Page 2 Img_1412
I used a small flat screwdriver to keep the sprung lever down whilst sliding the arm into the blade until it locked into position.
Aero Wiper Blades - Page 2 Img_1413
Wiper arms back on their spindles - it's a 10mm spanner that you need for that btw and don't over tighten, you don't want to strip those spindles - and the new blade's effectiveness was tested. The blade on the offside still sits 'off' the screen in the parked position as others have found, but the improvement in clearing water off the screen is vast.
Here's the link to the supplier again:
16/16 Aero Blades
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyTue May 22, 2012 4:57 pm
Good work Tim.
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyTue May 22, 2012 10:26 pm
Good stuff Tim, they certainly do make a difference clearing the water Smile
https://www.facebook.com/pastymaster
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 23, 2012 12:21 am
hey, cool showing from it, thank you for good info tim :-)
http://www.t2-c.de
http://www.t2-c.de
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyWed May 23, 2012 2:20 pm
Just ordered mine. Thanks for the fitting advice. I'll let you know how I get on. :-)
stoneyuk
stoneyuk
PostSubject: Re: Aero Wiper Blades   Aero Wiper Blades - Page 2 EmptyMon Oct 08, 2012 10:18 am
Just ordered a pair of these, as previous ones (from another supplier) did not fit.
Aero Wiper Blades
Page 2 of 4Go to page : Previous  1, 2, 3, 4  Next
