| BioFuel Shake-Up | |
+7timmm Tallulah Blue Seagull kiteman osg jj123vw TimV 11 posters |
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:20 pm | |
| Reading through his topic, just a few questions.
1/ As the small tank is for bio fuel, and If it always starts on the small tank then switches to the main tank once started, what would happen when the small tank becomes empty?
2/ As i don't have access to bio fuel, does that mean that if there is bio fuel still in the small tank that i will have to re-fill it if and when it is depleted?
3/ what would happen if petrol was put into the small tank instead of bio?
4/ what is the capacity of the small tank?
________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:30 pm | |
| The small tank is for petrol not Bio, Bio fuel goes in the large tank. Pertol has a higher octane rating so is need to start the engine, once it's running it then switches over to bio fuel in the main tank. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:36 pm | |
| Am lost altogether now. My technical knowledge as you might have realised by now is nil.
So,how then reversing the questions as my last post? ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:38 pm | |
| - Quote :
- 1/ As the small tank is for bio fuel, and If it always starts on the small tank then switches to the main tank once started, what would happen when the small tank becomes empty?
It's the other way round, the small tank is ONLY for regular unleaded petrol and (although no-one has any way to prove this) we suspect the small tank would only be used if the ECU determines a problem when starting as normal from the main tank when filled with bio-ethanol AND the outside temperature is below 15 degrees (ish). When the small tank does become empty/low - mainly due to evaporation it would seem - there should be a dash warning light that comes on. - Quote :
- 2/ As i don't have access to bio fuel, does that mean that if there is bio fuel still in the small tank that i will have to re-fill it if and when it is depleted?
Under normal (UK) use where the main tank contains regular unleaded, your van should happily run with nothing in the small tank although the dash warning light will be on. However most owners do keep the small tank topped up. AFAIK bio-ethanol is no longer available in the UK. We did however fill our main tank with E85 a couple of times while in France, 85% bio-ethanol and almost 1/2 the cost of unleaded. Tallulah ran like a dream although it wasn't cold enough to concern the engine into starting on the small tank. - Quote :
- 3/ what would happen if petrol was put into the small tank instead of bio?
See first answer above. - Quote :
- 4/ what is the capacity of the small tank?
Between 1 and 2 litres with a very short neck. It is advisable to fill using a petrol can rather than at the pump due to the risk of spillage etc. Hope that helps. ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:41 pm | |
| thank you.
so... basically i am ok to fill both the tanks safely with petrol? ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 12:52 pm | |
| - timmm wrote:
- thank you.
so... basically i am ok to fill both the tanks safely with petrol? Absolutely. Just be care full with the small one especially if filling at the pump. ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: BioFuel Shake-Up Mon Oct 20, 2014 1:06 pm | |
| Thanks....think mine was empty but it didn't have the warning light on the dash at all, but at the first time i went to fill my bus up, i started putting it in the wrong tank before i realised my mistake.
I only put a couple of squirts in, and then siphoned it out whereby lots of brown gooey stuff came out as well.... hence me thinking that was the boi tank.
And since then, my dash warning light for that tank has been on. ________________________________________________________________________________ Timmm
Cabin : Exec 015 Location : Merseyside Posts : 1554 Join date : 2010-09-21
| Subject: Re: BioFuel Shake-Up Wed Oct 22, 2014 4:37 pm | |
| alkylate petrolTimmm mentions 'brown gooey stuff' from his small tank. This was also what emerged from our small tank when it was emptied to re-fill it with the more stable alkylate petrol. osg | |
| Subject: Re: BioFuel Shake-Up Wed Oct 22, 2014 11:15 pm | |
| What's your thoughts on it. .. ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Thu Oct 23, 2014 2:37 pm | |
| The liquid syphoned from our small tank ( in 2012 ) was brown in colour but not really 'gooey' - more like petrol with a distinct brown hue. We assumed that this had been added at production time in Brazil and so must represent the regular fuel used there. No signs of rust, so not brown because of that. Haven't looked since then but I'll check what tank holds now. osg | |
| Subject: Re: BioFuel Shake-Up Thu Oct 23, 2014 3:00 pm | |
| Just re-checked the contents of our small tank. Full to near the top - clear, colourless fluid and a pleasant odour (Alkylate smells much nicer than ordinary petrol). So nothing used and the contents staying clean for over two years since contents replaced with Alkylate petrol. osg | |
| Subject: Re: BioFuel Shake-Up Thu Oct 23, 2014 8:22 pm | |
| So what's alkylate Petrol? ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Fri Oct 24, 2014 2:17 pm | |
| Timmm said - So what's alkylate Petrol? wrote:
Just click on the link in my Wednesday post above, or search 'Alkylate' osg | |
| Subject: Re: BioFuel Shake-Up Mon Oct 27, 2014 1:48 pm | |
| thanks osg... found it. ________________________________________________________________________________ Timmm
Ronnie Ringding
Cabin : Exec 082 Location : Perranporth, Cornwall Posts : 215 Join date : 2013-05-15
| Subject: Re: BioFuel Shake-Up Tue Oct 28, 2014 10:50 am | |
| I see this thread started in 2011. Have the government changed the fuel to 10% ethanol? I have had my airbay for 5 years now and have been running it on straight unleaded with no issues at all. When I have serviced it the plugs are all good. (indicator of poor performance). Should I have been using super-unleaded all this time?
________________________________________________________________________________ I am an Engineer. I will fix this!
| Subject: Re: BioFuel Shake-Up Tue Oct 28, 2014 12:02 pm | |
| mines 2011, it just gets whatever pump I pull up at put in to it at the time. I thought that as it is a modernish watercooled, that would be fine. ive had no issues yet and it seems quite good with the mpg as well. ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up Tue Oct 28, 2014 12:54 pm | |
| Both Aircooled AND Watercooled run fine on 95 RON unleaded. I'd expect no improvement in performance by putting 97 RON Superunleaded in the tank of a Watercooled but my Aircooled does 'seem' to run better on it. Could just be a placebo effect.
I do have to run my 911 on Superunleaded. Tis the law. ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: BioFuel Shake-Up Tue Oct 28, 2014 2:57 pm | |
| Thought I'd have a look at what the petrol was like after a couple of years in the starter tank (this is with fuel preserver added when I replaced it last time) There is a bit of colour difference compared with the fresh petrol on the left, but seeing as Ethanol isn't available here, I don't suppose it matters that much, as it's not going to be used. | |
| Subject: Re: BioFuel Shake-Up Tue Oct 28, 2014 4:05 pm | |
| The jar on the right looks very much like the situation when I first syphoned off the small tank. Perhaps the original factory fill included both petrol and fuel preserver. This would make sense if the expectation was that the small tank was likely to remain full and un-used. osg | |
RayC
Cabin : Club Location : Cheshire Posts : 396 Join date : 2014-05-01
| Subject: Re: BioFuel Shake-Up Wed Oct 29, 2014 4:24 am | |
| not wanting to hijack the thread but Danbury told me not to use super unleaded when we picked our camper up just regular unleaded
also some fuels are different colours you will find this if you fill up jerry cans from different stations eg texaco vs shell, some are even nearly red or green | |
| Subject: Re: BioFuel Shake-Up Wed Oct 29, 2014 8:55 am | |
| - RayC wrote:
- not wanting to hijack the thread but Danbury told me not to use super unleaded when we picked our camper up just regular unleaded
Yes, I heard this but I don't know why. Super unleaded should be fine in all engines. What is so special about ours that makes them unsuitable? More interestingly, what dressing it do? | |
| Subject: Re: BioFuel Shake-Up Wed Oct 29, 2014 2:14 pm | |
| RayC said - Quote :
- Danbury told me not to use super unleaded when we picked our camper up just regular unleaded
We have always gone along with the use of regular petrol to fit in with that advice for the main tank. For the small tank we put in Alkylate petrol on the assumptions that 1) none would ever be used 2) by filling the tank it would help to stop rust and 3) because it lasts better it would perhaps work better if there ever was emergency call on that tank. osg | |
| Subject: Re: BioFuel Shake-Up Thu Oct 30, 2014 1:06 pm | |
| I thought our 2011 aqua bay just has a 'normal' 1.4 polo fox engine in it.
Is this the case? as if so, wouldn't you just treat it as a normal 2011 plate engine would expected to be treat re fuel etc? ________________________________________________________________________________ Timmm
| Subject: Re: BioFuel Shake-Up | |
