 BioFuel Shake-Up
Go to page : Previous  1, 2
PostSubject: Re: BioFuel Shake-Up   Thu Oct 23, 2014 3:00 pm
Just re-checked the contents of our small tank.
Full to near the top - clear, colourless fluid and a pleasant odour (Alkylate smells much nicer than ordinary petrol). So nothing used and the contents staying clean for over two years since contents replaced with Alkylate petrol.
PostSubject: Re: BioFuel Shake-Up   Thu Oct 23, 2014 8:22 pm
So what's alkylate Petrol?
Timmm
PostSubject: Re: BioFuel Shake-Up   Fri Oct 24, 2014 2:17 pm
Timmm said
So what's alkylate Petrol? wrote:
Just click on the link in my Wednesday post above, or search 'Alkylate'
PostSubject: Re: BioFuel Shake-Up   Mon Oct 27, 2014 1:48 pm
thanks osg... found it.
Timmm
Ronnie Ringding
Cabin : Exec 082
PostSubject: Re: BioFuel Shake-Up   Tue Oct 28, 2014 10:50 am
I see this thread started in 2011.
Have the government changed the fuel to 10% ethanol?
I have had my airbay for 5 years now and have been running it on straight unleaded with no issues at all.
When I have serviced it the plugs are all good. (indicator of poor performance).
Should I have been using super-unleaded all this time?
I am an Engineer. I will fix this!
http://www.trevianlodge.co.uk
PostSubject: Re: BioFuel Shake-Up   Tue Oct 28, 2014 12:02 pm
mines 2011, it just gets whatever pump I pull up at put in to it at the time.
I thought that as it is a modernish watercooled, that would be fine.
ive had no issues yet and it seems quite good with the mpg as well.
Timmm
PostSubject: Re: BioFuel Shake-Up   Tue Oct 28, 2014 12:54 pm
Both Aircooled AND Watercooled run fine on 95 RON unleaded. I'd expect no improvement in performance by putting 97 RON Superunleaded in the tank of a Watercooled but my Aircooled does 'seem' to run better on it. Could just be a placebo effect.
I do have to run my 911 on Superunleaded. Tis the law.
PostSubject: Re: BioFuel Shake-Up   Tue Oct 28, 2014 2:57 pm
Thought I'd have a look at what the petrol was like after a couple of years in the starter tank (this is with fuel preserver added when I replaced it last time)
There is a bit of colour difference compared with the fresh petrol on the left, but seeing as Ethanol isn't available here, I don't suppose it matters that much, as it's not going to be used.
PostSubject: Re: BioFuel Shake-Up   Tue Oct 28, 2014 4:05 pm
The jar on the right looks very much like the situation when I first syphoned off the small tank. Perhaps the original factory fill included both petrol and fuel preserver. This would make sense if the expectation was that the small tank was likely to remain full and un-used.
RayC
PostSubject: Re: BioFuel Shake-Up   Wed Oct 29, 2014 4:24 am
not wanting to hijack the thread but Danbury told me not to use super unleaded when we picked our camper up just regular unleaded
also some fuels are different colours you will find this if you fill up jerry cans from different stations eg texaco vs shell, some are even nearly red or green
http://treadltd@gmail.com
PostSubject: Re: BioFuel Shake-Up   Wed Oct 29, 2014 8:55 am
Yes, I heard this but I don't know why. Super unleaded should be fine in all engines. What is so special about ours that makes them unsuitable? More interestingly, what dressing it do?
PostSubject: Re: BioFuel Shake-Up   Wed Oct 29, 2014 2:14 pm
RayC said
Quote :
We have always gone along with the use of regular petrol to fit in with that advice for the main tank.
For the small tank we put in Alkylate petrol on the assumptions that
1) none would ever be used
2) by filling the tank it would help to stop rust and
3) because it lasts better it would perhaps work better if there ever was emergency call on that tank.
PostSubject: Re: BioFuel Shake-Up   Thu Oct 30, 2014 1:06 pm
I thought our 2011 aqua bay just has a 'normal' 1.4 polo fox engine in it.
Is this the case? as if so, wouldn't you just treat it as a normal 2011 plate engine would expected to be treat re fuel etc?
Timmm
BioFuel Shake-Up
