 Brazilian Head Lining
Andy
PostSubject: Brazilian Head Lining   Sun Jan 08, 2012 10:48 am
I am on the look out for a standard headlining from a tin top kombi to put in my partially converted panel van...
So if anyone is going to convert from a tin top, to a pop top I will buy your old headlining.
PostSubject: Re: Brazilian Head Lining   Sun Jan 08, 2012 10:59 am
I don't think there is any headlining on a regular Kombi apart from that over the cab area.
Just did a search and found this of member Max's tintop:
Unless you're wanting the already converted headlining, in which case try dazdub as he installed a poptop himself and may have the original Danbury headliner kicking around.
Jackoski
PostSubject: Re: Brazilian Head Lining   Sat Dec 07, 2013 4:56 pm
Hi, got a danbury headliner.
Has a hole for a drop down tv which I still have also.
Let me know if you are interested or you want any pics.
Mike
Ianvwk
PostSubject: Re: Brazilian Head Lining   Mon Dec 09, 2013 4:12 pm
Hi Andy,
We have a headliner we have just removed from a 2010 Danbury Tin top, its the rear section as were fitting a roof to it.
Your welcome to have it FOC, it just needs collecting.
If you don't already have them you would need the side strips that hold the lights and speakers, we can also supply these for you.
Ta,
Ian
www.braziliankampers.co.uk
http://Www.vwkampers.com
