 Empi shifter
Go to page : Previous  1, 2
Rachelvw
Cabin : Exec 077
PostSubject: Re: Empi shifter    Thu Jan 12, 2017 9:09 pm
Empi gear stick fitted so out for a spin in the snow to check it out brilliant much better
PostSubject: Re: Empi shifter    Thu Jan 12, 2017 9:18 pm
my empi has been in a long time now and I have had no problems with it and yes it is definitely a lot better Smile
PostSubject: Re: Empi shifter    Fri Jan 13, 2017 7:11 pm
Agree with Daz, it makes all the difference, a job worth doing
Rachelvw
Cabin : Exec 077
PostSubject: Re: Empi shifter    Fri Jan 13, 2017 7:47 pm
Yeah I agree it's much better
Cabin : Exec 086
PostSubject: Re: Empi shifter    Tue Oct 24, 2017 2:58 pm
@dazdub wrote:
Hi all just put an empi shifter in my bay very easy to fit 2 bolts and a bit of rubber and carpet to trim very nice shift now well worth fitting
Hi Daz
i'm thinking about getting one myself, possible for a layman with very little technical knowledge to fit and set up/adjust and did you have to trim the carpet a lot?
Cabin : Exec 086
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 3:23 pm
@kiteman wrote:
Just fitted mine today. Was a bit of a faf getting it to work properly but it's all sorted now. Simple job when you know what your doing.
The gear change is so much more positive. Would definitely recomend.
If anyone else is going to fit one, you neeed to use bigger of the two spacers that are supplied.
What issues did you find Kiteman? I'm thinking of getting one myself
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 3:58 pm
Only small draw back eith empi if you small hands the loop for reverse. Tim
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 4:06 pm
Dee James - kiteman no longer has his Kombi - his post was some while ago
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 4:19 pm
That rules Donald Trump out then. Very Happy
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 4:28 pm
@Dee James wrote:
Hi Daz
hi yep a bit of carpet trimming and the hand brake will need to be adjusted to only a bit of free play
Cabin : Exec 086
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 4:41 pm
@dazdub wrote:
@Dee James wrote:
Hi Daz
Thanks Daz,
the shifter bit looks doable, i'll read up on handbrake adjustment
Cabin : Exec 086
PostSubject: Re: Empi shifter    Fri Oct 27, 2017 4:58 pm
thanks for the heads up Scooby, i was advised to add to an existing thread rather than start another Wink
Empi shifter
