| It's stripping time! | |
 | Subject: Re: It's stripping time! Fri Apr 10, 2015 8:40 am | |
| thank you a very lot for the good photos.
________________________________________________________________________________ http://www.t2-c.de
Cabin : Exec 008 Location : Central Scotland Posts : 1731 Join date : 2010-09-04
 | Subject: Re: It's stripping time! Fri Apr 10, 2015 9:01 pm | |
| Well managed to get the rockers built up, but forgot to take pics(trying to get engine back in this evening), the mounting blocks I linked to from VWHeritage are the wider ones which do not require the extra washer like the original ones fitted to the engine. So if your needing rocker shaft mounting blocks and you want to replace like for like get the narrow ones it's what was fitted from the factory. My wider one's just replace the original block and nylon washer altogether. Glad I cleared that up So the engine went back in this evening once the tappets were adjusted. Front pic  Left pic  Right pic  and Back  ...and were in, going to connect it all up tomorrow fingers crossed it'll start  |
 | Subject: Re: It's stripping time! Fri Apr 10, 2015 9:11 pm | |
| Looks amazing. Going to be a bugger to keep clean  ________________________________________________________________________________  Ginger man without a ginger van  |
 | Subject: Re: It's stripping time! Sat Apr 11, 2015 7:49 am | |
| Brilliant stuff ST but can't help but feel there's a bit more blinging needed. Those inlet manifolds for starters  |
 | Subject: Re: It's stripping time! Tue Apr 14, 2015 7:19 pm | |
| This is the final sump guard pics painted and fitted Front and rear bracket  Close up of front bracket with towing eye thread  Close up of rear bracket  Altogether with sump guard and towing eye screwed in  without towing eye  ....and a side view bear in mind bus is still jacked up  |
buzzinfinity
Cabin : Exec 059 Posts : 58 Join date : 2012-05-31
 | Subject: Re: It's stripping time! Tue Apr 14, 2015 7:36 pm | |
| This must be the definitive guide for whoever's clutch goes next and wants to upgrade a bit! |
 | Subject: Re: It's stripping time! Sun Jan 01, 2017 4:36 pm | |
| So it went from Original  After Dropped Spindles  Then back again just slightly lower than original as I have smaller side wall tyres still fitted.  |
 | Subject: Re: It's stripping time! Sun Jan 01, 2017 5:11 pm | |
| When we were leaving the ferry onto Vatersay it was quite steep and I had a lot of revs when I bumped down off the ramp, this is when the engine started producing a rattling sound when we stopped in this layby at the top of the hill to investigate, but couldn't find anything obvious so we drove on.  During the rest of the trip it would not go away and seemed worse at idle. When we got to the campsite at Balranald we started to investigate, we discovered that the tin ware bolts had come loose with the vibration of the engine, and found the exhaust was rattling inside the silencer boxes, but this wasn't the root of the problem. It seemed to come from the fan housing so I disconnected the fan belt to determine if it was engine/alternator(A new one was just fitted)or fan related. It stopped so it was either alternator or fan or both. The alternator felt smooth when spun by hand and I couldn't do anything with the fan unless I removed it and that involved removing the engine which I wasn't going to do. So we lived with it for the duration of the island hopping and will check it out once home. So once home engine was taken out and we removed the alternator and fan assembly  I put the old alternator back in as the new one seemed to not spin as freely as it. So engine went back in and it was still vibrating  , so engine came back out again and as I was dismantling the fan off the alternator I noticed the crack just behind the washer and nut holding the fan on. So fan was junk new one ordered and alternator sent back for testing.  When I received the new fan and alternator they were fitted and everything was running smooth again apart from the exhaust which is the next instalment. |
 | Subject: Re: It's stripping time! Sun Jan 01, 2017 5:46 pm | |
| Oh before the exhaust while the engine was out I discovered another broken spring washer on the rocker shaft. So I swapped both out for bolt on one's. Before  After with bolt on rocker shafts installed  Another upgrade to give you piece of mind for longer trips. |
 | Subject: Re: It's stripping time! Sun Jan 01, 2017 6:00 pm | |
| So onto the exhaust I took it back to Stainless Creations where I got it fitted and they agreed to swap the one box making the noise under warranty and for a small fee swap the other one as well. Before  After with new boxes and sounds so quiet again  however does need a polish  |
Cabin : Flight 001 Location : Cobham, Surrey. U.K. Posts : 13704 Join date : 2009-09-27
 | Subject: Re: It's stripping time! Sun Jan 01, 2017 8:34 pm | |
| Sorry hope you weren't looking long that's the other side which hadn't broken. I got the bolt up rocker shafts from vw heritage Tim along with some extra shims. It is a bit time consuming getting the correct float but then no more broken rocker shims. |
Cabin : Flight 004 Location : Reading Posts : 8360 Join date : 2010-12-12
 | Subject: Re: It's stripping time! Sun May 27, 2018 2:30 pm | |
| Yipppeeeee Photobucket reinstated the picture links, saves me adding them again. More time to work on Phileas  |
 | Subject: Re: It's stripping time! Mon Jul 23, 2018 10:54 pm | |
| Started some rust repair on Phileas's offside front wheel housing where the seat runner is a before   Seat runner cut out but will need to enlarge tommorow to remove all rust
Last edited by Skytiger on Tue Jul 31, 2018 8:50 am; edited 1 time in total (Reason for editing : Added another pic) |
 | Subject: Re: It's stripping time! Tue Jul 24, 2018 8:38 am | |
| Wow Always amazed what you can doo! Will watch with interest - as always ________________________________________________________________________________ Proud winners of Spike's Trophy 2017
Scooby - Born To Run  |
Cabin : Exec 015 Location : Merseyside Posts : 1136 Join date : 2010-09-21
 | Subject: Re: It's stripping time! Wed Jul 25, 2018 8:05 pm | |
| Skytiger Any tips on how this arises and how to prevent it? Is this area a double skin layer? osg |
 | Subject: Re: It's stripping time! Wed Jul 25, 2018 8:32 pm | |
| Yes osg it's double skin it has a 2mm plate underneath in the wheelarch positioned under the seat rail for reinforcement I guess but it is spot welded throught the seat rail then the wheel housing skin and then the 2mm plate. It is not seam welded around the edge of it underneath so if the sealer fails water gets in and rusts from the inside. So check your sealer around edge of plate is intact to prevent moisture getting in. My wheel housing skin under the seat rail was pretty much rusted away. |
 | Subject: Re: It's stripping time! Wed Jul 25, 2018 9:11 pm | |
| I had to cut out more to get rid of the rust  So this is what I have cut out so far  As you can see on the first pic there is more rust at the bottom so this had to come out aswell.  Thats me back to clean metal no more cutting yeah  Started to make the new patch hopefully get welding tommorow |
 | Subject: Re: It's stripping time! Thu Jul 26, 2018 10:20 am | |
| I'm trying not to think how scary it is Scooby cutting a big hole in my kombi where I normally sit |
 | Subject: Re: It's stripping time! Fri Jul 27, 2018 10:34 pm | |
| Patch is in and started to weld, I did weld all the way round not completed yet though, forgot to take pic afterwards, so here is the start.  The fit is lovely at the back  hopefully get welding tommorow if it stops raining  |
Cabin : Exec 012 Location : wales Posts : 2895 Join date : 2009-10-16
 | Subject: Re: It's stripping time! Sat Jul 28, 2018 7:29 am | |
Cabin : Flight 044 Location : Alderley Edge Posts : 1075 Join date : 2013-08-10
