 Rear lap belt mounts
PostSubject: Rear lap belt mounts   Tue Jan 14, 2014 5:24 pm
Unfortunately, over the weekend, whilst putting down the R and R bed, I carelessly managed to trap the lap belt underneath and managed to crack the plastic cover on the buckle.   Rolling Eyes   Embarassed
It still works OK, but I expect some sharp eyed MOT tester will spot it, so I'm going to replace it.
I think it is a Securon 210,  fitted by Danbury.
My question is, does anyone know if it is a captive bolt that I can remove from inside, or am I going to have to crawl underneath with a spanner whilst a mate undoes it from above. I'm hoping it is the former that was done in Brazil on the original build.
sparkysteve
Cabin : Exec 035
PostSubject: Re: Rear lap belt mounts   Tue Jan 14, 2014 7:11 pm
Hi Dizzy,
There are captive nuts in the seat belt mounting points.
When I fitted my 3 point belts I had to remove the lapbelts BUT be warned they are very hard to remove.
The under-seal gets right in the threads so suggest a good soaking of WD40 before makes a massive difference. Go gently as they can snap off the welds on the captive nuts so suggest you loosen 1/2 a turn then re-tighten 1/4 of a turn and keep this going until it frees up.
PostSubject: Re: Rear lap belt mounts   Tue Jan 14, 2014 7:34 pm
That's a relief about the captive nuts, and thanks for the advice about taking it slow.
Much appreciated for the reply Steve, cheers   Smile
PostSubject: Re: Rear lap belt mounts   Wed Jan 15, 2014 10:37 am
You reckon we believe that's how you broke the belt with the bed dizzy?! You saucy devil! Wink
PostSubject: Re: Rear lap belt mounts   Wed Jan 15, 2014 11:32 am
lol! Sorry to disappoint Tim, but I'm not as athletic as I used to be.......I think the bromide they put in the tea at my school 60 years ago is just starting to kick in.   Laughing
PostSubject: Re: Rear lap belt mounts   Wed Jan 15, 2014 3:10 pm
If it's only just taking affect dizzy then you've done very well! (According to Young Mr. Grace. )
