 More on our eventful trip to Danbury...
PostSubject: More on our eventful trip to Danbury...   Wed Mar 25, 2015 3:25 pm
Blog (www.C13MPR.com)
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 4:11 pm
What was wrong with the wheels themselves?
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 4:24 pm
The front one was damaged on the motorway. It wouldn't hold air under pressure. The rear two, along with the tyres, had become misshapen, possibly because I hadn't moved the van from Oct to March.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 6:46 pm
I'm no mechanic, but why would the rims get misshapen simply by the van not being moved. Is it just the type you have fitted or is it common to 'stainless' rims?
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 6:54 pm
My neighbour says he's seen it before with alloys.
RayC
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 8:54 pm
I've only seen wheels misshaped with impact damage or BMW rims which were susceptible to cracking
are the wheels suitably load rated for the Kombi if they are aftermarket alloys?
http://treadltd@gmail.com
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 8:57 pm
The alloys came with the van from new, RayC.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 9:01 pm
This would be my concern as the wheels should never buckle just sitting still, inferior batch of wheels perhaps?
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 9:06 pm
Maybe, but they've been replaced so all sorted.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 9:18 pm
This is what I was thinking. 17" rims on a T2 are a relatively new thing. I'm wondering if others were checked if they'd show the same characteristics. Keep in mind that Absinthe is a well used BraziBay so will have covered a lot more kms than your average 3-4 year old Kombi. All for good reasons of course!
Plus she often pulls a loaded trailer.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 9:26 pm
Valid points, Tim. Danbury thought the trailer might not have helped, although truth be told we don't always take it with us.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 9:30 pm
Well worth checking what the weight rating is for your alloys, should be stamped on the inside rim or the inside of one of the spokes. If there, it will be a weight in kg.
PostSubject: Re: More on our eventful trip to Danbury...   Wed Mar 25, 2015 10:40 pm
The trailer is not putting any weight down onto the wheels of the bus really at all, that's what the trailers wheels are for taking the weight of the trailer and contents.
RayC
PostSubject: Re: More on our eventful trip to Danbury...   Thu Mar 26, 2015 8:13 am
if you see my thread on tyres and pressures you can see loads, I doubt 17" wheels will have the load capacity required for the Kombi mt 15" alloys say 600 KG on them
the trailer should not apply much extra as the ball weight will be low, but the effective damping offered by the 17" tyre will be much lower as the sidewall is smaller and stiffer
It might be worth putting your van on a free weigh bridge and seeing the axle weights then double checking the tyre load index and wheel capacity to be certain everything is OK
PostSubject: Re: More on our eventful trip to Danbury...   Thu Mar 26, 2015 1:44 pm
We've the same alloys as Abs so slightly worried!! At VWK tomorrow so will gauge their thoughts..
PostSubject: Re: More on our eventful trip to Danbury...   Thu Mar 26, 2015 2:37 pm
Next person to view is 26000 views
Well done
PostSubject: Re: More on our eventful trip to Danbury...   Thu Mar 26, 2015 2:40 pm
Sorry but had to log out and back in again but it gone upto 26004. The Ocd was kicking in
At least it's an even number
Thanks Marcus. Trouble is that number includes the "bots" that trawl all over looking at things. Evil or Very Mad
PostSubject: Re: More on our eventful trip to Danbury...   Fri Mar 27, 2015 7:45 pm
We needed a new rear tyre today , before MOT Dave at VWK detected large bulge on inner tyre wall which he suggested was probably caused by a pot hole.. Fortunately no damage to alloy but could have easily have blown out just like Abs.. Need to stay well clear of the pesky pot holes..
PostSubject: Re: More on our eventful trip to Danbury...   Fri Mar 27, 2015 7:46 pm
Oops. Hope it's all sorted BB.
PostSubject: Re: More on our eventful trip to Danbury...   Fri Mar 27, 2015 7:53 pm
All sorted thanks Abs, we didn't have a clue so thankful that it was picked up on the service really..
Think I'll inspect the tyres s little more often and more thoroughly from now on..
RayC
PostSubject: Re: More on our eventful trip to Danbury...   Fri Mar 27, 2015 8:15 pm
What is load rating of 17" tyres?
brazilianvwbay.com :: Out and About in your Brazilian Bus :: Great Bay Trips-
