HomeSearchRegisterLog in
10 years of BraziBay fun!!
Share
 CTEK Battery Charger Install
Go to page : Previous  1, 2, 3
fat_pastor
fat_pastor
Cabin : Exec
CTEK Battery Charger Install - Page 3 Empty
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyWed Oct 09, 2019 6:34 pm
Brilliant, many thanks
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyWed Oct 09, 2019 6:35 pm
Very Happy
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyThu Oct 10, 2019 7:23 am
Just one thing that crossed my mind about that feed to the starter battery. I recommend NEVER starting the engine whilst the hookup is still connected as you’d then have 2 sources of charge going into both batteries and I’m not sure if the system could handle that.
CTEK Battery Charger Install - Page 3 Melogo11
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyThu Oct 10, 2019 10:43 am
Tim said
I've got this charger in Tango too - similarly without the starter battery being connected. Seems reasonable to assume that if you run a wire to the correct terminal, it ought to do the job.
Just to clarify our settings because there are lots of versions of the Waeco with different product numbers.
We have version 915-012TB
It has a set of 4 switches which are set on(up),down(off),down(off),up(on) which programmes a starting point of 14.4 volts for 4 hours
The terminal nearest to the switches provides a 1 amp trickle for the positve terminal of the starter battery
The middle terminal is the feed to the positive terminal on the camping battery
The terminal on the right ( furthest from the switches ) is for connection to the negative terminal of both batteries.
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyThu Oct 10, 2019 8:07 pm
Thanks OSG that's exactly what I have just that the starter terminal isn't connected. That's what I plan to connect with a 3amp Fuse inline near the starter battery. Just need to find a nice route through now 🤔
Sent from Topic'it App
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 03, 2020 10:32 am
@Dennis wrote:
Working well what I meant with protection did you connect it direct to back of blue plug or did you put it through a low rating mcb if not you are relying on the protection of the hookup box wherever. Tim
Hi Tim, was planning to wire my CTEK into the blue hookup - what rating MCB would you recommend?
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 03, 2020 12:26 pm
Which model do you have. Tim
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 03, 2020 12:29 pm
MXS 3.8
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 03, 2020 5:26 pm
Hi spec on charger 0.5 amp rms i would put in a 2amp mcb type b or c. Tim
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 17, 2020 5:38 pm
Hello, I have a ctek and it works a treat. Rather than wire it to the hook-up, can't I just plug it in to the 240v supply in the van when I'm hooked up? It's all fused so should be fine,right?
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 17, 2020 6:22 pm
That’s what I do. Never had a problem and works a treat.
PostSubject: Re: CTEK Battery Charger Install   CTEK Battery Charger Install - Page 3 EmptyFri Jan 17, 2020 6:33 pm
Yep will be okay. Just if permantly fixed just less hassle and no cables in living area of van and croc clips can come off the poles of the battery. Tim
Page 3 of 3Go to page : Previous  1, 2, 3
