 refitting gear stick
5 posters
andyl
andyl
refitting gear stick Empty
PostSubject: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 12:57 pm
Hi
Am retrofitting my old gear stick as despite multiple adjustments and opening of mounting holes i am still not entirely happy with EMPI .However i have forgotten orientation of fitting original floor plate .There was recently a post showing this but i am afraid i can't find .Any help would be much appreciated
thanks
Andy
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:08 pm
Hi Andy,
I can't help you with the original floor plate, but my personal opinion is not to give up on the EMPI. I suffered similarly, until I got somebody who really knew what they were doing to re-weld the lock-out plate and re-fit and adjust the EMPI. It has worked like a dream since. I would never go back. The EMPI is cheap and cheerful, and works well when you get it right. CSP and Scat are reckoned to be better quality though (but more expensive).
Alan
andyl
andyl
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:30 pm
thanks but intend to refit although perhaps this will remind me how the original was .May be then i will revert to the EMPI !!!
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:51 pm
refitting gear stick Melogo11
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:55 pm
Who did you use to sort your empi stick out Alan
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:58 pm
Jon Mawby at Autopoint Knutsford. He's the proprietor. It's an independent garage, but he's a VW enthusiast who owns a T2 and T25 himself.
TimV wrote:
Gearstick washers??
This thread?
And 'trouble selecting 2nd gear'. (Haven't been able to do the link)
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 1:59 pm
I'm guessing it was like stirring a bowl of porridge. Good luck! Wink
andyl
andyl
PostSubject: Re: refitting gear stick   refitting gear stick EmptyTue Feb 16, 2016 4:42 pm
thanks all for comments and Tim found the thread i was referring to .The idiot question is on the inner rim of the plate there are two slight indents one side formed by the turned down edge and a single slightly curved cut out on the other .The diagram appears to show the two indents to the passenger side and can anyone confirm this .(i assume this has a relevance to the reverse gear lock out )
thanks again
