 Fitted Bed Sheets?
T2D2
10 posters
Fitted Bed Sheets? Empty
PostSubject: Fitted Bed Sheets?   Fitted Bed Sheets? EmptySun Nov 26, 2017 9:30 pm
Hello lovely people.
Although we don’t have our camper yet, we are busy researching and preparing Very Happy
Please does anyone know if fitted sheets are available for the Danbury T2 Rio?
I know we can use normal sheets and that’s no hardship, but was just wondering if there are fitted bed sheets available out there, because we haven’t found any yet? Cool
Many thanks, Badger.
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptySun Nov 26, 2017 9:32 pm
Not aware of any, we use a regular double fitted sheet with a thick blanket underneath.
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptySun Nov 26, 2017 9:45 pm
This is turning out to be a long wait........
And it’s not even December yet!!!! bounce
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 12:04 am
Hi again. We use Duvalays which are a foam mattress and sheet and duvet cover all in one. You can remove the covers for washing. If on our own they can be used singly with a side opening or you can put them side by side as singles or with a jiggle around of the covers both openings can be from centre for snuggling
M
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 6:25 am
Thank you.
Not heard of Duvalays. I will look into them Smile
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 7:56 am
Most of us on here need to lie on some sort of extra mattress topper as many of us are getting on a bit. If you look up past threads you'll find all the different solutions about bedding.
M
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 8:47 am
We put the mattress from the roof bed on top of the rock-and-roll bed, and put a single fitted sheet on it. The bed is about 42" wide and a standard single bed is 36" wide, so a single sheet just about fits, given that the mattress is quite thin.
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 10:37 am
We have a Diamond conversion and a kingsize topper mattress fits perfect with fitted sheets but a double size duvet. Tim
T2D2
T2D2
Cabin : Exec 085
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 12:55 pm
We our just using a double sheet not fitted, just tuck it down the sides, it didn't seem to come lose. We havent gone for a topper and it seems pretty comfy (we have cloth seats though not leather) Smile
bounce bounce
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 2:12 pm
We use 50mm thick memory foam and 'mummy' sleeping bags - 3 or 4 season - always been as warm as toast! Smile
Cabin : Exec 086
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 4:32 pm
Only been out once so far but same as Scooby, mummy sleeping bags mattress although you've reminded me i still need to remove the two un needed layers of carpet in the back to get the bed more even, might go for a memory foam mattress after that
Cabin : Exec 074
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 7:04 pm
after several years of using sleeping bags on the original mattress we have new foam for the mattress / rear seat and a memory foam mattress topper cut to fit the shape. We just use a regular sheet & duvet now.
what is best in life ?
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 7:24 pm
We too have a piece of memory foam cut to size. We then use a standard double sheet over the top.
PostSubject: Re: Fitted Bed Sheets?   Fitted Bed Sheets? EmptyMon Nov 27, 2017 9:16 pm
We have a bill brown roll up mattress that works well for us. Not the cheapest solution though.
Fitted Bed Sheets?
» New Seats Fitted
» Any one else fitted a oil pressure gauge
