HomeSearchRegisterLog in
Your club is 10 years old now!!
10 years of BraziBay fun!!
Christmas Dinner - November 16th more details to come.
Share
 Injector needed
kirk
Injector needed  Empty
PostSubject: Injector needed    Injector needed  EmptyThu Jul 18, 2019 7:55 am
120000 on clock and off to france VWt2c 2004 1600 aircooled.
I really need one new injector. Part vw0409060314
Does anybody know where I can get one?
Kirk
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 9:41 am
Have you tried Just Kampers and VW Heritage?
See Showroom section of this Forum
sparkysteve
sparkysteve
Cabin : Exec 035
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 10:59 am
Hi.
The injectors used on Brazilian aircooled are made by Bosch.
The problem is that they are only available for the south American market. So you cannot get them in Europe.
Some were available early on via imports but they have dried up.
I found you can get a rebuild kit and I refurbished mine myself.
You could always get yours clean and tested by an injector company. I think that will be your only real choice unless you can get a set imported.
Steve.
Injector needed  Logo_s11
kirk
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 12:28 pm
Thanks for the reply. I have managed to get 3 new ones so will put them on with the best of the cleaned ones. I had fuel in the oil so one one more of the original ones leaking.
Does that sound like a plan?
sparkysteve
sparkysteve
Cabin : Exec 035
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 1:42 pm
Hi. I made a simple test rig with a tank of paraffin and a air compressor and pressure gauge.
Then found a simple timer trigger box off Amazon which fires different pulse widths.
Checked before and after cleaning.
The write up is on my blog.
Regarding the fuel in the oil. Could be a stuck on injector, too high fuel pressure or a faulty evap valve.
A fuel pressure check will rule out too high pressure. Worth checking evap valve as this can dump fuel rich vapour into the inlet manifold.
Steve
Sent from Topic'it App
kirk
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 2:55 pm
Thanks I will have a look at pressure and evap valve.
Cheers.
PostSubject: Re: Injector needed    Injector needed  EmptyThu Jul 18, 2019 7:14 pm
https://www.ebay.com/itm/4pcs-0280150553-Fuel-Injector-nozzle-For-VW-Kombi-1-6-Acool-Flow-Matched-new-/113586506591?_ul=GB
Don't know if these are any good, same as Bosch equivalent to vw part number, drawback they are from China.
kirk
PostSubject: Re: Injector needed    Injector needed  EmptyFri Jul 19, 2019 8:01 am
Thanks they look correct.
I have saved the link:-)
Injector needed
