| Interior LED light | |
| Subject: Interior LED light Fri May 23, 2014 3:24 pm | |
| After seeing HarryHornet's LED lights at Dubs At The Park decided to do some of my own. I decided to use the existing interior lights that Danbury fit and replace the fluorescent tube with an LED strip instead. Managed to get 5M of LED strip for the bargain price of £2.50 off Ebay I removed all the electronics and transformer from behind the end cover and wired the LED strip to the units switch. with the cover back on ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Interior LED light Fri May 23, 2014 4:23 pm | |
| Nice work. What a difference and at a bargain price too. | |
| Subject: Re: Interior LED light Sat May 24, 2014 6:45 pm | |
| Cracking job Kiteman, what a bright spark Can you tell me which seller on Ebay. | |
| Subject: Re: Interior LED light Sat May 24, 2014 7:12 pm | |
| Does this reduce the lecky consumption, as I thought the strip lights were supposed to be low draw anyway? | |
| Subject: Re: Interior LED light Sun May 25, 2014 9:10 am | |
| Strip lights use less than normal incandescent lamps, but do have a high start up current. LEDs have zero startup and use very little power, better all round ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Interior LED light Sun May 25, 2014 12:44 pm | |
| - kiteman wrote:
- Strip lights use less than normal incandescent lamps, but do have a high start up current. LEDs have zero startup and use very little power, better all round
Sounds (and looks) good then. Next trick, mood lighting with different colored strips and the option to change as required. | |
| Subject: Re: Interior LED light Sun May 25, 2014 3:04 pm | |
| They do multicolour LED strips with remote control on ebay as well ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Interior LED light Sat Jul 12, 2014 3:50 pm | |
| With some of the left over Led strip I decided to make a light for the awning. All I did was wrap the strip around some pvc tube I found in the garage, add some cable that is long enough to plug in the 12v socket and put a hook at the top so it can be hung from the awning ________________________________________________________________________________ Ginger man without a ginger van | |
neillitesteer
Cabin : Business Location : Flimwell Posts : 69 Join date : 2011-10-25
| Subject: Re: Interior LED light Sun Jul 13, 2014 4:20 pm | |
| - kiteman wrote:
- They do multicolour LED strips with remote control on ebay as well
Bought one of these, took a chance at £7 Very surprised at how well it worked! | |
| Subject: Re: Interior LED light Sun Jul 13, 2014 5:01 pm | |
Very surprised at how well it worked! Looking forward to seeing how you hook it up to some new engineering project. Technicoloured brick perhaps or maybe different colours depending on speed. | |
neillitesteer
| Subject: Re: Interior LED light | |
