HomeSearchRegisterLog in
10 years of BraziBay fun!!
 Where is second fuse on eberspacher heaters
Vman
Where is second fuse on eberspacher heaters Empty
PostSubject: Where is second fuse on eberspacher heaters   Where is second fuse on eberspacher heaters EmptyWed Jul 15, 2020 4:44 pm
Hi eberspacher heater never worked... Found a blown 25 amp fuse connected to the leisure battery... (Changed this but still no heat or any thing) Looking at earlier posts it states that these heaters are normally connected to the mains battery.... But my van is a Devon conversion one of the original half dozen.. (in their words)....so may be different than Danbury.... On one of the earlier posts regarding heaters it states there may be a second fuse.... does anyone know where this might be...I have checked the main fuse panel on the van and all those are ok.....I can only assume the 25 amp fuse was for the heater as everything else works ok any help appreciated
