 Interior Advice - door cards
7 posters
Interior Advice - door cards Empty
PostSubject: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 4:01 pm
Hi folks,
Looking for a wee bit of advice or inspiration!
As you're probably aware, we've fitted out our camper ourselves but we've come up against a bit of a stumbling block for the boot area. Our next step is door cards and to be honest I think the Newton ones look pretty good, so we'll probably go down that route. But what have people done for the panel below the window behind the rear seat? This pic will explain the area I mean:
Photobucket
Does anyone have any suggestions or photos? Or thoses of you who have Newton door cards in the rear, did the card extend to this part of the bus?
Mmmm....any thoughts?
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 4:10 pm
Newtons dont do a card for that area I think it is due to the sweep of curves as it would prove difficult to stay in lace. Olive has the carpet that is spray glued onto the bodywork. It might be a better way to do it using carpet. If you do, heat the carpet on the underside to make it more plyable before your spray the glue on and it will fit the curves tight.
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 4:32 pm
I've put felt up on mine. Got it from Ebay.
Ebay link
Interior Advice - door cards Imag0711
To get it to stick, just used spay adhesive on the interior side wall. Rub it down lightly to give the glue something to stick to.
Make sure you mask off the areas you don't want the glue to go on. It can get a bit messy.
Even glued a little pocket on the side so I've got somewhere to keep my phone when i'm asleep
Interior Advice - door cards Img_4810
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 4:48 pm
Newton do now do panels to fit the rear sides:
Newton Rear Inner Panel
Interior Advice - door cards Melogo11
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 4:58 pm
Thanks for the info folks.
I decided to have a wee look at Newtons site again and discovered the panels, Tim you've beaten me to the link Laughing I think that's the way we'll go, now it's time to choose colours, wish me luck!
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 5:29 pm
Lol - don't forget to post some pix when it's all done.
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Aug 06, 2011 8:33 pm
That sounds great, dont forget to post the image once youve done it
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Aug 08, 2011 10:44 am
Well after much deliberation, we decided on the colour for our door cards Very Happy
We considered ever possibility of colour combination, taking into account the black seats, the off white units, deep purple lino, the viper green the bus will eventually be and we decided on ...........black Embarassed pretty boring I know, but we plan on 'blinging' it up with some shiny door furniture!
Order was placed this morning and will hopefully be ready in a few weeks. Will post photos when they're here.
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Aug 08, 2011 11:58 am
Excellent! As you'll be one of the first members to install the rear panel sections, could you do a photo-shoot of them going in please? I'm curious about the fit.
Bloke_Off_The_Internet
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySun Oct 09, 2011 3:26 pm
I'd quite like to see that too -- did you get them installed in the end?
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Oct 10, 2011 5:34 pm
Here are some pics of the panel sorry no fitting pictures as we were in a rush to finish the camper for a wedding last Saturday. The bride was arriving in the camper.
We used the screws that where originally used to hold the panels on the opposite side from the sliding door because these had covers on them. The ones supplied are silver and would stick out to much for me. We only used four as we thought the bed foam would hold the bottom in.
Interior Advice - door cards 10102011137
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Oct 10, 2011 5:43 pm
The fit is quite tight up against the wheel arch panel and the back panel. The holes in the panel don't line up with the originals so we drilled fresh holes in the panel and body to best spread the load over the panel.
The middle section over the fuel pipe is quite stiff it is made up of different layers of strong card to enable it to flex but it could be softer, as when the top was screwed in the bottom splayed out because of it hitting off the fuel pipe. Hopefully with foam installed it will take it's shape now.
Overall I like it because it matches the other door cards and covers the metal but it is a two man fitting job.
Interior Advice - door cards 10102011138
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Oct 10, 2011 6:13 pm
You may find that you will need the odd fixing below the foam to hold the shape
But despite the points you have raised, it still looks good Cool
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Oct 10, 2011 8:32 pm
Ace, thanks for posting Smile
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptyMon Oct 10, 2011 8:52 pm
Very nice Smile
PostSubject: Re: Interior Advice - door cards   Interior Advice - door cards EmptySat Oct 15, 2011 6:41 pm
Some more pics of Newtons doorcards
door panel (hopefully Santa will bring some bling door furniture! santa )
Interior Advice - door cards DSCF5319
fuel neck panel
Interior Advice - door cards DSCF5327
boot panel
Interior Advice - door cards DSCF5329
sliding door panel (note to self - still need to veneer the buddy seat!)
Interior Advice - door cards DSCF5330
