Cabin : Exec 072 Location : Central Dorset Posts : 321 Join date : 2012-01-22
Subject: Poptop Insulated Cosy Sat May 19, 2012 6:50 pm
Just thought I'd post up a few pics of the insulated cover I've sorted for Robin. It completely cuts out light into the poptop and I hope may lead to more cosier nights in Robin. Cheers - Batty
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 9:48 am
Hi Folks It is a slightly mouldable material and thus is okay to mould a little to fit tightly - but I have a secure strap at the joint to hold it all together. It is a bit fiddly to get in to position on my own - but should be easier with two people. I left it on overnight in moderate winds and it was completely secure. Cheers - Batty
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 8:09 pm
lostlogik wrote:
Didn't realise light through the material was an issue. But it looks snug, if a bit of a chore putting it on.
It's not an issue, but it is canvas so you do get a degree of light bleeding through if the sun is shining in the am. Not enough to wake up a youngster though! Putting the thermal stuff on would cut out the light more.
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 9:24 pm
I don't think I need worry too much about light bleeding through the canvas in the morning. Having a sunroof will have more of an effect sunlight-in-the-morning-wise
Guest Guest
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 9:47 pm
how much and where from,
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 9:55 pm
All in All about £35 in materials - and made it myself in a couple of hours.
Cheers - Batty
Guest Guest
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 10:05 pm
thanks ,poss another job to do ,keep us informed how it works in "the field" so to speak ,is it actually waterproof ,i was thinking if it wasnt it would be very heavy when wet !!
NorthPoles
Cabin : Club Location : York Posts : 252 Join date : 2012-02-08
Subject: Re: Poptop Insulated Cosy Sun May 20, 2012 10:56 pm
