as you can see in this photo i have an air vent in the pop top roof and after seeing various pics on here i wondered if it was possible to retro fit a sunroof in the same place, has anyone done this and where would i get one from? excluding danbury themselves obviously as that would be too expensive
Don't bother stay with your skylight much better as the position of you skylight looks central which would give you the same problem I have it is covered with the bed also you cannot open it when it rains. Tim
Subject: Re: sunroof Mon May 21, 2012 9:38 pm
The air vents, particularly the Fiamma ones, whether open or closed, permanently allow air to circulate within the cabin, so are healthier for both BraziBay and occupants.
Subject: Re: sunroof Tue Jun 05, 2012 5:56 pm
how looks it from the inside from the car? does it good helps for good air? and is it loud when you drive? have you done this self on the car? all the best, ps i find it good
