 Rack and pinion
Ianvwk
erosser
6 posters
erosser
Rack and pinion Empty
PostSubject: Rack and pinion   Rack and pinion EmptyFri May 09, 2014 3:12 pm
I am the owner of a 2008 plate Brazilian Bay named Enfys (welsh for rainbow) which has been converted to RHD by Danbury.
I am considering trying to improve the steering and after research have found that there seems to be two camps. Those who favour the Danbury power steering system which means instaling a rack and pinion system instead of the steering box and those who favour the lite steer power steering option which uses the original steering box.
As a matter of interest has anybody fitted the danbury rack and pinion system without the power steering ?
I believe this unit is produced by creative engineering. Is it really impossibly heavy without the power steering ?
Ianvwk
Ianvwk
PostSubject: Re: Rack and pinion   Rack and pinion EmptyFri May 09, 2014 4:08 pm
Hi,
We had a 09 Rio into stock that had the Danbury (creative engineering!) rack and pinion fitted , the camper was lowered on alloys and was almost impossible to drive! We took it to Neil at lite steer who modified one of his EPAS kits to fit and it was like a different camper! Very positive and easy to drive. I personally have Rack and Pinion (red 9 design wishbone) on my classic that Neil at litesteer played with and its very good!
Hope that helps Ian VWkampers.co.uk
www.vwkampers.co.uk
http://Www.braziliankampers.co.uk
steveb
steveb
Cabin : Exec 056
PostSubject: Re: Rack and pinion   Rack and pinion EmptyFri May 09, 2014 7:39 pm
Hi,
I've got a 2004 aircooled had the Litesteer EPAS system fitted by Neil at Litesteer and at the same time he replaced the original Brazilian steering box with a late bay steering box. Apparently the steering box fitted in Brazilian bays is mechanically closer to the split screen era and so can have a significant amount of play. Sufficient to say the the combination of the Litesteer EPAS and the late bay sttering box worked wonders!
PostSubject: Re: Rack and pinion   Rack and pinion EmptySat May 10, 2014 9:52 am
What's wrong with a little 'wandering' now and then?
We like 'wandering around' with Scooby
Roo b Roo
 jocolor
PostSubject: Re: Rack and pinion   Rack and pinion EmptyTue May 13, 2014 9:02 am
We have the rack and pinion fitted, it does make the steering more responsive and less prone to wander but it needs setting up properly, which ties you to danburys as noone else can make much sense of it. Also the universal joints come loose and then can suddenly snap, leaving you with no steering.
Matt.
Rack and pinion Img_2014
PostSubject: Re: Rack and pinion   Rack and pinion EmptyTue May 13, 2014 10:57 am
Has that happened to you Matt?
Rack and pinion Melogo11
PostSubject: Re: Rack and pinion   Rack and pinion EmptyWed May 14, 2014 9:22 pm
Yes.
Matt.
Rack and pinion
» New Brazilian Bay Roof Racks!
» Canoe rack?
» New Bike Rack
» Who needs a roof rack?
» What's on your roof rack?
