 water leak around windscreen wiper spindle outlet
4 posters
docmark
docmark
Cabin : Exec 022
water leak around windscreen wiper spindle outlet Empty
PostSubject: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed May 31, 2017 10:26 am
Hi
Driving in rain recently I had water dripping down under the drivers dash - I had previously had to seal the windscreen because of a leak but have now found that the wiper spindle on the drivers side seems fused into its casing and the whole thing turns in the rubber grommet that passes through the body-work - and water comes in in heavy rain
Has anyone else had this happen - and how easy is it to replace the spindle with its housing?
Mark
PostSubject: Re: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed May 31, 2017 11:07 am
Hi Doc have had this happening since purchased van in 2010. Tim
PostSubject: Re: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed May 31, 2017 12:05 pm
docmark wrote:
Hi
Mark
Hi Mark,
I had to replace the spindle recently, when the spindle sheared and the passenger side wiper wouldn't work. I bought a new one from Just Kampers and fitted it on-site at Brand Autos. Ours was the passenger side, but I'd say it was fairly straightforward (as long as you don't drop the washers down the gap between the outer and inner skins - which I did!)
The spindle clips into place and it's just a bit fiddly from then on!
PostSubject: Re: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed May 31, 2017 9:42 pm
Subject: Re: water leak around windscreen wiper spindle outlet   Today at 11:07 am
Same here..lol
PostSubject: Re: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed May 31, 2017 9:43 pm
Only ours since 2007 !
dougie watchorn
PostSubject: Re: water leak around windscreen wiper spindle outlet   water leak around windscreen wiper spindle outlet EmptyWed Aug 16, 2017 11:11 pm
My spindles leak too,and my windscreen and my pop top on the front hold down catches!!!!!! mines more like a leaky boat than a bay!!!!!!!!
» Camping Site Mains Supply Unit - 3 Outlet
» Lovely Mint Green Aqua - Spotted today Ashford Designer Outlet
» Painted Dashboard
» Over wintering and door leak
» New source for wiper blades
