 roof rack bolts
4 posters
Boxy
Boxy
roof rack bolts Empty
PostSubject: roof rack bolts   roof rack bolts EmptyThu Feb 15, 2018 10:42 am
hi all does anyone know where i can get a replacement nut for one of the bolts on my curved roof rack as it appears to have fallen off.?
PostSubject: Re: roof rack bolts   roof rack bolts EmptyThu Feb 15, 2018 10:50 am
I replaced mine with wing nuts to make it easier to fit/remove the rack.
Local ironmongers.
roof rack bolts Melogo11
PostSubject: Re: roof rack bolts   roof rack bolts EmptyThu Feb 15, 2018 11:19 am
Do you mean the individual slats, or fixing to the roof?
For the former, I 'lost' one while re-varnishing it, so needed to buy a pack at B&Q - 4x45mm pack of bolts and nuts, zinc plated (ref AVF - 853708), called machine screw, pan head slotted.
PostSubject: Re: roof rack bolts   roof rack bolts EmptyThu Feb 15, 2018 11:53 am
I once spent a morning trying to get the clamps to undo, the nut on the inside was just spinning, and no way was I able to get a spanner on it, so in the end I jammed a piece of rod against it.
roof rack bolts Imgp1610
The problem was that the flare of the inner plate is too wide, and any rust on the nut just makes it spin, so once it was off, I replaced the square nut with a wing nut, but reversed so it jammed against the side to stop it spinning.
roof rack bolts Imgp1611
If you need a bolt for the clamp, screwfix do 'socket cap screws' which are the ones with the allen key head.
https://www.screwfix.com/search?search=socket+cap+screws
Boxy
Boxy
PostSubject: Re: roof rack bolts   roof rack bolts EmptyThu Feb 15, 2018 9:44 pm
thanks chaps. it was where the metal cage bars sitr on the slats. think i have sorted it but will see if i have the right size in the morning.
roof rack bolts
» New Brazilian Bay Roof Racks!
» Who needs a roof rack?
» Roof rack nets?
» Pop Top, Roof Rack and Awning
» Roof rack for Danbury T2?
