| Potential van purchase but need advice. | |
+5sundialsoft Scooby Tallulah Ianvwk dazdub 9 posters |
Scoot68
Cabin : Economy Posts : 4 Join date : 2019-04-01
| Subject: Potential van purchase but need advice. Mon Apr 01, 2019 9:49 pm | |
| Hi, I am looking for some help and advise with regards to buying a 2007 water-cooled model. I test drove it today and found the gear selection was a bit tricky to find. It also crunched a couple of times when changing down a gear. The van has covered 31000 miles and had been regularly serviced. Is there a problem with it or is it me!! Thanks in advance, Mark | |
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 6:44 am | |
| Hi gearbox’s are week in brazilian bays if it crunches on down shift sound like it needs replacement or rebuild. Was the owner able to drive it with out crunching? | |
Scoot68
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 7:45 am | |
| Hi, it did crunch a couple of times going into 2nd, not all the time. He said you need to to get the revs down as it doesn't have synchromesh. He did drive it but was double the clutching it. Thanks | |
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 8:11 am | |
| - Scoot68 wrote:
- Hi, it did crunch a couple of times going into 2nd, not all the time. He said you need to to get the revs down as it doesn't have synchromesh. He did drive it but was double the clutching it. Thanks
sounds like it needs box sorting | |
Scoot68
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 8:17 am | |
| Thanks. Any idea how much it will cost? | |
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 8:35 am | |
| - Scoot68 wrote:
- Thanks. Any idea how much it will cost?
sorry don’t know as I fixed my gearbox myself do a search on forum will come up with lots results | |
Ianvwk
Cabin : Business Posts : 633 Join date : 2010-10-27
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 9:03 am | |
| Hi Mark,
We have some nice stock for sale, all sold with a full warranty and mechanical check over...
Ian
www.vwkampers.co.uk
ps replacment gearbox is £1500 - £2000 supplied and fitted. ________________________________________________________________________________ www.vwkampers.co.uk
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 9:30 am | |
| Or it could just be the adjustment plate beneath the gear stick needs adjusting... ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 10:02 am | |
| Hi Mark If you have any concerns or doubts about a purchase and it does not feel right our advice would be to walk away. We are sure there will be another suitable Kombi coming along soon which will not have such issues. All the best Roo b Roo ________________________________________________________________________________ Proud winners of Spike's Trophy 2017 Scooby - Born To Run | |
Cabin : Exec 074 Location : Northumberland Posts : 428 Join date : 2014-10-02
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 12:19 pm | |
| - Scoot68 wrote:
- Hi, I am looking for some help and advise with regards to buying a 2007 water-cooled model. I test drove it today and found the gear selection was a bit tricky to find. It also crunched a couple of times when changing down a gear. The van has covered 31000 miles and had been regularly serviced. Is there a problem with it or is it me!! Thanks in advance,
Mark The gearstick adjustment is easy so that can be done in a half an hour and there are youtube videos showing how it's done. It's just a case of knowing what to do first, take it apart noting where everything goes and re-centering everything and testing. I did it to my van a few years ago and it was really simple to do. You do it in the front cab of the van, not underneath. If the adjustment does not sort it then there is a problem. Could be a worn clutch cable which needs a few parts or the gearbox. It's the seller's job to do all this so if you are in doubt or don't get the right answers probably walk away time. ________________________________________________________________________________ what is best in life ?
brabay
Cabin : Club Posts : 107 Join date : 2011-10-15
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 3:16 pm | |
| Hi those gearboxes do have synchros on all gears and if its crunching then there is likely some problem, I can rebuild your gearbox to stock or upgrade it with german parts and components, it comes with guarantee and will be still cheaper than replacement gearbox | |
| Subject: Re: Potential van purchase but need advice. Tue Apr 02, 2019 10:12 pm | |
Mark Hi Mark, well from what I can see you've got a lot of useful advice here, much of it invaluable if you already owned the van. However, as you don't, I think I'd be tended to heed Scooby's advice (see below), unless you're sure you could fix it yourself/get it fixed relatively easily. Hope this helps P. - Scooby wrote:
- Hi Mark
If you have any concerns or doubts about a purchase and it does not feel right our advice would be to walk away. We are sure there will be another suitable Kombi coming along soon which will not have such issues. All the best Roo b Roo | |
Cabin : Club Location : Leicester - the centre of the world - sorry England Posts : 521 Join date : 2011-04-06
| Subject: Re: Potential van purchase but need advice. Wed Apr 03, 2019 10:10 pm | |
| If you are going to spend a considerable amount of money on a van then it needs to be in full-working order. Either the current owner fixes or walk away. Not worth the risk of 'it might be the adjustment plate,' etc. Only my opinion though. | |
Scoot68
| Subject: Re: Potential van purchase but need advice. Thu Apr 04, 2019 8:01 am | |
| Thank you all for taking the time to offer advice. I think I will leave it consider my other options. | |
| Subject: Re: Potential van purchase but need advice. | |
