 headlamp bulb replacement?
2 posters
elliec
elliec
headlamp bulb replacement? Empty
PostSubject: headlamp bulb replacement?   headlamp bulb replacement? EmptySun Jun 30, 2019 10:47 am
Hi all. Noticed yesterday that one of my headlights is working on full beam but not as side light..if that makes sense!
is it likely to be a simple bulb needing to be replaced? or something more complicated? In other words can I attempt it myself or do I need to head to the garage?
Elliec
PostSubject: Re: headlamp bulb replacement?   headlamp bulb replacement? EmptySun Jun 30, 2019 8:10 pm
Hi Elliec,
more than likely it's the dipped beam has gone and, as it's a combined bulb, will need to be replaced.
If you've not upgraded your bulbs, it's worth doing so; you'll get more power from them. Replace both at the same time.
https://brazilianvwbay.forumotion.com/t2970-get-a-brighter-view-upgrade-your-bulbs?highlight=bulbs
Powerbulbs do a great after-service, if required. Use code TIME25 to get 25% off.
» headlight converters and spare bulb kit
» Possible replacement seats.
» Replacement flooring
» Pop top replacement canvas
» Front beam replacement
