Subject: Faulty crankshaft sensor help Sun Aug 02, 2020 7:51 pm
Hi We are currently on holiday in Cornwall and our 2013 T2 Kombi has broken down. AA have said it's a faulty Crankshaft sensor. We need to wait until tomorrow to try and call a garage but would be grateful for any advice. Are the sensors easy to obtain and would a mechanic be able to replace on site as we are are currently sitting on a camp site! Any help would be appreciated thank you
Subject: Re: Faulty crankshaft sensor help Sun Aug 02, 2020 9:47 pm
The sensor could be the same as a Vw Fox 1.4 and both have very similar engines
RosieMcJosh
Cabin : Club Posts : 3 Join date : 2020-06-18
Subject: Re: Faulty crankshaft sensor help Sun Aug 02, 2020 11:09 pm
Thank you for your replay.
How long does it take to fit and are the sensors easy for garages to order?
Subject: Re: Faulty crankshaft sensor help Mon Aug 03, 2020 12:05 pm
some are very easy to fit others can be a nightmare just depends on were it is and what’s around it old 1 needs removal first to get part number off it so you get the right one
RosieMcJosh
Subject: Re: Faulty crankshaft sensor help Mon Aug 03, 2020 2:19 pm
Thanks again Dazdub
Subject: Re: Faulty crankshaft sensor help Mon Aug 03, 2020 3:26 pm
According to VW ETKA, the crankshaft impulse sensor is part number 032906 433, and knock sensor 030 905377c (Bosch equivalent 0261 231146. Both have a lot of equivalents, but as always get your supplier to double check suitability. Hope you get it sorted.
Subject: Re: Faulty crankshaft sensor help Wed Aug 05, 2020 2:40 pm
Hi there, I am having the same issue with my 2010 Brazilian Camper. The computer diagnostic said the crankshaft sensor was faulty, so I had this changed and the engine light is still coming on. How did you sort out your problem?
I would be grateful for any help as the little local garage I use has given up!
Many thanks
Ciaran
simonhavers
Cabin : Club Posts : 3 Join date : 2020-01-05
Subject: Re: Faulty crankshaft sensor help Sat Feb 26, 2022 5:46 am
I have solved a crank shaft sensor problem and just posting on here in case it is helpful to others:
Van: 2010 VW T2 Kombi Brazilian Bay Engine: BTJ
Problem: Van struggles to start when cold. Have to run an electric fan heater in the engine compartment for 20 minutes. Then takes a minute or two of turning the engine over before it will run at all. It then runs coughing/spluttering and stalling for another minute or so. Weirdly, it then finally bursts into life and runs very well. The transition from coughing/spluttering to running well is not at all gradual, it’s as if someone flips a switch.
Solved by: Bishop's Stortford (Herts / Essex border) Branch of VWAuditec. http://www.vwauditec.co.uk/bishops-stortford-branch.html Independent VW Audi specialist. Top quality service
Report: Interrogated fault memory using VCDS diagnostic equipment; Found data for 16706 engine speed sensor G28; Established component as crankshaft sensor; Removed inlet manifold to access; Replaced G28 crank sensor part 03C 906 433 E G28. Part £84. Labour £290
Outcome: very happy. Useless van stuck at home is now back in action! Thank you VW Auditec for your can-do attitude and open-mindedness to an imported VW that is "not on the system"
TimV likes this post
David126
Cabin : Club Posts : 1 Join date : 2022-07-04
Subject: Re: Faulty crankshaft sensor help Mon Jul 04, 2022 10:17 am
Hello All,
I've just joined the group and have a similar issue with my 2007 van. The AA rescued me on my way back from France and picked up a faulty crankshaft sensor fault. Have ordered the part and shall share the results if successful. I suspect the ignition leads haven't been replaced in the correct order though. If there is anyone who wouldn't mind posting a pic of their engine bay with the ignition leads I'd be grateful. Thank you in advance and liking the group, thank you for adding me.
simonhavers
Subject: Re: Faulty crankshaft sensor help Mon Jul 04, 2022 10:40 am
here you go
good luck with it
TimV and David126 like this post
kedinter
Posts : 1 Join date : 2023-05-12
Subject: Re: Faulty crankshaft sensor help Fri May 12, 2023 6:57 pm
Hi everybody I was searching for a part and I found this forum! Maybe somebody can help me, my crankshaft isn’t working anymore. I was searching for a new one but with the number on the part I took of the engine I get another part. The crankshaft number on the part is 032906433 if I order the same one with this number I get one with a wrong installation dept, I need one with an installation dept of 23.9. Can anybody help me with this?
