 Internal floor base material?
2 posters
Snoops
Snoops
Internal floor base material?  Empty
PostSubject: Internal floor base material?    Internal floor base material?  EmptyTue Aug 24, 2021 2:33 pm
Hi all, I've got a soft spot on the internal floor under the lino, possibly a hole, I've checked the under carriage, all is solid and undersealed. I'm looking to replace what's  underneath the lino, but before I start pulling stuff out to get the floor up, I was wondering if anyone  knows what will be underneath, I'm thinking some sort or ply but use Snoops quite a bit so want to be prepared so I can get it done quickly and get the floor back down, Thanks, Neil
Snoops
Snoops
PostSubject: Re: Internal floor base material?    Internal floor base material?  EmptyWed Sep 01, 2021 10:37 am
Turns out that it was 4mm ply. The waste from the sink had split and water had got under the floor and made the existing ply damp, no rust fortunately, but took all the old ply up, rubbed the metal floor pan down, primed and sprayed it (didn't need it but might as well while you're there) before fitting new ply, lino flooring and replacing the old waste pipe with new dishwasher waste pipe, a bit more durable than the thin britle stuff fitted.
Alfy likes this post
PostSubject: Re: Internal floor base material?    Internal floor base material?  EmptyWed Sep 01, 2021 5:32 pm
Glad you resolved this by a-ply-ing your own skill set! Laughing
Snoops likes this post
Snoops
Snoops
PostSubject: Re: Internal floor base material?    Internal floor base material?  EmptySat Sep 04, 2021 2:43 pm
Internal floor base material?  20210910
Internal floor base material?  Img-2010
All done.
PostSubject: Re: Internal floor base material?    Internal floor base material?  EmptySat Sep 04, 2021 6:25 pm
Looks great Smile
» £30 floor
» Internal lighting idea
» Frank has an internal revamp!
» Internal door pulls . . .
» Fitting Internal LED Lights
