 Using OBD for dashboard display?
5 posters
Jane&Jamie
Jane&Jamie
Using OBD for dashboard display? Empty
PostSubject: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyMon May 23, 2022 3:47 pm
Does anyone have experience linking an OBD plug (bluetooth or hardwired) to a dashboard display (either resembling gauges or as a 'head up' display)? It seems a simple way of having live information on things like oil and water temperature; volts and amps. If fault code deciphering were included that would be a bonus, but not our main interest. I assume plugged-ins (as opposed to bluetooth to phone) are USB powered, and that an auto-cut-off is essential so that it it does not drain the battery. All and any insights and intelligence welcome!
Bandyrooks likes this post
PostSubject: Re: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyMon May 23, 2022 5:53 pm
I use dash command app and a blue tooth obd, but do not leave plugged in when not using as the 12v supply to the obd is a permanent supply.
PostSubject: Re: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyMon May 23, 2022 6:35 pm
Perhaps this past topic will be of interest
OBD uses
TimV likes this post
daveb101
daveb101
PostSubject: Re: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyFri May 27, 2022 8:48 am
Interestingly on my van a water cooled bay. If it's plugged in before starting the van the immobilizer is permanently activated until the odb device is removed. I assume this is an anti theft protection.
PostSubject: Re: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyFri May 27, 2022 10:27 am
Does not happen on mine i can leave it plugged in but the power red light on front of obd on all time
Bandyrooks
Bandyrooks
PostSubject: Re: Using OBD for dashboard display?   Using OBD for dashboard display? EmptyFri May 27, 2022 2:15 pm
I'm going to follow this, as I'm interested in getting more info from the engine - the dashboard on Juniper is very lacking in information!
» Digital RPM and Coolant Temp Display
» Dashboard Lighting
» Bugs & buses on display in Rotherham this Saturday,
» New Brazi Bay on display at Coventry Transport Museum
» Painted Dashboard
