 Help with fridge not working
2 posters
Greg
Help with fridge not working  Empty
PostSubject: Help with fridge not working    Help with fridge not working  EmptySun Feb 12, 2023 2:54 pm
Just been for first camp out and think fridge has packed up, it's making a knocking noise roughly every minute and not cooling any ideas? Fridge is the original so a bit elderly. ☺Is it worth repairing or am I looking at a new one? If new any suggestions for supplier I'm based in Hampshire
2006 Rio Danbury conversion
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyMon Feb 13, 2023 2:43 pm
Chest fridge or side opening one?
Help with fridge not working  Melogo11
Greg
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyMon Feb 13, 2023 4:16 pm
Hi Tim side opening to the right the fridge is located below a sink unit original Danbury layout cheers Greg.
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyMon Feb 13, 2023 9:20 pm
Waeco/Dometic variant then.
These require the leisure battery to be in good health. If that is the case then it’s most likely expired. We like Vitrifrigo fridges as a decent replacement at VW Kampers. We get them from Grassroots Leisure.
Greg
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyMon Feb 13, 2023 10:18 pm
Cheers Tim do you know which model I can buy that fits the gap because I think the compressor to the fridge is under my gas bottle in the cupboard next to the fridge leisure battery is new and reads fully charged when connected to campsite hook up.
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyTue Feb 14, 2023 8:34 am
C42L with the separate compressor. We relocate the compressor from where Danbury installed it to the base of the centre cupboard. Don't forget you need to add ventilation holes for the compressor.
Greg
PostSubject: Re: Help with fridge not working    Help with fridge not working  EmptyWed Feb 15, 2023 5:51 pm
Hi Tim I've looked on grassroots website this is the only company that mentions coupling connection available to compressor does that mean I would not have to cut a hole in my cupboard as I think Danbury have built everything around the fridge and compressor cheers Greg.
brazilianvwbay.com :: Out and About in your Brazilian Bus :: Kombi Kitchen-
