 Where is idle revs adjust on a air cooled
2 posters
Vman
Where is idle revs adjust on a air cooled  Empty
PostSubject: Where is idle revs adjust on a air cooled    Where is idle revs adjust on a air cooled  EmptySun May 28, 2023 12:37 pm
Hi any one know if there is a screw or such to alter the idle revs on the engine a picture of such screw would be appreciated thanks
sparkysteve
sparkysteve
Cabin : Exec 035
PostSubject: Re: Where is idle revs adjust on a air cooled    Where is idle revs adjust on a air cooled  EmptyFri Jun 02, 2023 5:41 pm
Hi. There is not an idle adjustment like a carb.
The idle is controlled by the ECU. It open and closes a idle actuator to maintain 850 rpm when at idle.
The actuator is mounted behind the throttle body and air manifold. It opens or closes to control the air bypassing the throttle body.
It looks like a silver can with two pipes and an electricalconnector. You can disconnect and give it a good clean as it does get grime. You can also test with 12v to see if it opens and closes.
It does have a factory set screw gap which allows a small idle air so make sure that's open a little.
Can you confirm what symptoms you are suffering from?
Also check out my blog site for diagnostic manuals.
Steve
Where is idle revs adjust on a air cooled  Logo_s11
Vman
PostSubject: Re: Where is idle revs adjust on a air cooled    Where is idle revs adjust on a air cooled  EmptySun Jun 11, 2023 7:21 pm
Brilliant thank you do you have any thoughts on using the thicker oil as apparently this improves oil pressure when hot
Vman
PostSubject: Re: Where is idle revs adjust on a air cooled    Where is idle revs adjust on a air cooled  EmptySun Jun 11, 2023 8:01 pm
P.s Steve 20/50 oil appernatly gives better oil pressure as runs thicker when hot
.. after fitting my oil presure gauge my presure is not great when the engine is running hot sitting at 1.5 bar on a 5 bar gauge starts up OK on 2.5 bar also when at hot idol it's 0.25 bar apparently the thicker oil would help any one know any down sides to using it ...p.s yes fitting a oil presure gague is mixed blessing ha
» Air cooled and Water cooled running costs
» Rear brakes adjust clean
» Air Cooled or Water Cooled that is the question?
» hi all air cooled bay
» 2006 Air Cooled Tin Top
