Subject: Central storage unit Fri Feb 04, 2011 3:29 pm
I have had this drawn up and costed by a small factory I use for my projects I work on during my worklife. It is made of 18mm MFC (same material as in your van) The dimensions will fit between the seats and the rear edge is to stop it sloping on the cab floor and will also stop the unit sliding forward when braking. It is divided into two sections with hinged tops, there is also a small drawer at the front. I was going to put on cup holders but decided you could screw on the cup holder that is for a T25 from VW Heritage. There are variuos veneer effect finishes but I am sure we could source the same board that is in the Danbury range. I can get them for just under £200 plus postage. If anyone is interested or if you would like to post some ideas let me know.
Baydreamer
Cabin : Club Location : medway kent Posts : 426 Join date : 2010-04-11
Subject: Re: Central storage unit Sat Feb 05, 2011 9:41 am
Thats a better price to others ive seen. Im still waiting for my design to be completed due to work commitments but the top design is along the lines of my thoughts too. I like the use of the draw on the bottom as a simple means of addition storage also.
Subject: Re: Central storage unit Sat Feb 05, 2011 5:06 pm
May even get then cheaper if we can buy in larger quantities
belgiumbay
Cabin : Club Location : Currently Korea (used to be belgium) Posts : 315 Join date : 2009-10-11
Subject: Re: Central storage unit Sun May 08, 2011 2:35 pm
Set of diagrams for a hippo type front box:
Knocked these up this morning. fairly general and can be adapted to add draws etc ...will probably build one when we get back to the UK this year before heading off to croatia - click thumbnail to open
