Subject: Re: Driving a LHD bay Mon Sep 06, 2010 8:02 pm
I need to get my van checked out, it obviously isnt safe to drive!! maybe Im just of a nervious disposition. Those of you with aircooled engines must have bleeding ears after hitting those speeds!
P.S. get Albert back from the windows installer this week after a long wait.... take it from me dont convert a panel van just not worth the agro!! watch this space for some picture updates.
Subject: Re: Driving a LHD bay Mon Sep 06, 2010 8:07 pm
Hey chairboy, it will be worth it because you're making your Bay "yours." Also it makes for an interesting bit of history to your Bay and makes this site richer for hearing about your experience doing it.
On the other point, why do you feel nervous about speed in your Bay? Is it displaying some symptom that causes you concern? If so what?
Subject: Re: Driving a LHD bay Mon Sep 06, 2010 8:28 pm
Hi tim. Only joking really, but must admit I tend to keep around 60 on motorways due to sway and high revving, hitting 70 plus the engine must be screaming! I have a bit of play in the steering but not bad, I will be fitting some guages soon but on those motorway runs I do worry about cooking the engine, rear end gets really hot, I noted the previous post about hot bumpers with interest, bottom line Ive only had the van a short while so still feeling my way around it
Re the windows, still pleased I've done it, people go on about preserving the vans, if it was an early bay I wouldn't do it but I like to look out when I'm laying in bed!
Will post pictures elsewhere when van is back, got all the interior sitting in the garage waiting to go in so will be very different from the usual when done, watch this space! Have a great time at van fest, would be there but jetting off on hols.
Subject: Re: Driving a LHD bay Mon Sep 06, 2010 8:36 pm
I suspect because you have a panel van that the noise factor is much greater when you are at speed. Once you've got all your camper kit in there I'm sure it'll seem much quieter. I can certainly recommend the fitting of an oil temp gauge along with a sump plug sender. Also consider using a semi-synthetic oil as it protects the engine better at higher running temperatures.
Andy
Cabin : Club Location : Swaffham, Norfolk Posts : 165 Join date : 2010-08-09
Subject: Re: Driving a LHD bay Mon Sep 13, 2010 8:46 pm
Quote :
I too have a bare Air Cooled Panel Van, and at anything over 55Mph I cant hear the stereo, and above 60Mph I cant hear the wife! (so its not all bad!)
I had never driven anything LHD before this, and was a bit worried as to how I would get on, but had absolutely no problems at all.
The only thing I have trouble with is when coming out of a slip road sometimes the angle isn't quite right and the mirrors are useless, and go to look over my right shoulder and all I can see is the inside of the sliding door, but this is obviously only a problem to panel vans.
