 40amp fuse off main battery ( for leisure battery) keeps blowing ?
2 posters
stanthevan
40amp fuse off main battery ( for leisure battery) keeps blowing ? Empty
PostSubject: 40amp fuse off main battery ( for leisure battery) keeps blowing ?   40amp fuse off main battery ( for leisure battery) keeps blowing ? EmptySun Apr 14, 2024 5:19 pm
Hi All
I just wondered if anyone has had a similar issue on their van as struggling to pin point ?
Within minutes of starting my engine the fuse for the leisure battery (connected to the main battery blows)
Dan
PostSubject: Re: 40amp fuse off main battery ( for leisure battery) keeps blowing ?   40amp fuse off main battery ( for leisure battery) keeps blowing ? EmptySun Apr 14, 2024 6:51 pm
I think the fuse is in danger of blowing if one battery is well charged and the other battery is flat. Check if this is the case then if needed charge up the flat one separately before re-connecting.
Also we were advised to only insert a new fuse when the engine is running.
TimV likes this post
stanthevan
PostSubject: Re: 40amp fuse off main battery ( for leisure battery) keeps blowing ?   40amp fuse off main battery ( for leisure battery) keeps blowing ? EmptyMon Apr 15, 2024 7:31 pm
Thanks ever so much - ill check that out 👍
» Leisure Battery
» Leisure battery
» Change your leisure battery (Aircooled)
» What size leisure battery and why
» mains power packs as leisure battery
