Cabin : Club Location : Currently Korea (used to be belgium) Posts : 315 Join date : 2009-10-11
Subject: couscous royale Tue Jul 10, 2012 11:35 am
needs two pots but each cook separately
1 packet of cold ready cooked chicken legs - called gringottes in france think you can get them in UK in clod meat counters - if not 5 or 6 small chicken legs
500g Merguez sausage (if you can not get merguez then grilling chorizo)
garlic to taste in our case an entire head
1 tin mixed veg (macadonian if possible - green beans, carrots, peas, sweet corn)
half a jar tomato pasta sauce without meat
Moroccan spice mix good spoon full or mix of sweet paprika, cumin and coriander will do
chicken stock cube
125g couscous per 2 persons
cook sausage in big boiling pan add garlic crushed after fat starts running add chicken to either cook or heat through with lid on add spices cook for another minute add pasta sauce and enough water to make a sauce cook through till meat is done
take of the heat and set aside
in second pan bring 1 british mug cup of water to boil for each 125g of couscous with some butter if available and chicken stock cube add couscous turn off heat and cover for 5 minutes rewarm the royale
server couscous on plate with royal over the top
serve with loads of fresh baguette traditional
Lulu
Cabin : Club Location : Royal Wootton Bassett Posts : 154 Join date : 2012-01-03
