 Replacing the two tube lights in the back with LEDs
Cabin : Exec 074
Replacing the two tube lights in the back with LEDs Empty
PostSubject: Replacing the two tube lights in the back with LEDs   Replacing the two tube lights in the back with LEDs EmptyTue Apr 24, 2018 10:42 am
I have fitted the first of two lights replacing the horrid flickering tubes we have put up with for years. Now (after a coffee) I will do the other one complete with step by step photographs and make a blog which I will link to here.
You simply need to buy two 12 volt LED strip lights of the correct length ready wired and connect a red wire and a black wire.
The old tube fittings and cover are retained together with the switch so it looks the same until you switch on.
I used a large and small star screwdriver, wire snips, wire strippers, a soldering iron, some heat shrinkable sleeve (to insulate the new connections), a stanley knife, a battery drill with small metal bit and a hair dryer.
Total time was under an hour for 1 light.
Always disconnect your van from the mains before doing any electrical work.
Wordpress blog on LED lights
what is best in life ?
» You Tube Video
» Fitting Internal LED Lights
» Replacing sink with some shelving
» Replacing Roof Gas Struts
» Dub Tub running lights
