A problem with the roof inside catching the material
3 posters
Author
Message
Lou Whiting
Cabin : Club Location : Salisbury, Wiltshire Posts : 3 Join date : 2011-08-07
Subject: A problem with the roof inside catching the material Sun Aug 07, 2011 11:26 pm
Has anyone else got a Danbury T2 and had problems with the back part of the roof on the inside? When you lower the roof the rear LHS (as you face the front) has a bolt attachment to hold the stanchion in place. The bolt attachment has eaten into the carpet, wood and even made 2 small holes in the roof material and the campers are only 3 months old. You can prevent this by really pulling the roof forward but I think it slips back as driving. A rubber backing would sort it. Just wondered if anyone else has thsi? Lou
Subject: Re: A problem with the roof inside catching the material Mon Aug 08, 2011 7:31 am
I suggest you take this particular Kombi back to Danbury for them to check the fitting of the roof and make necessary rectifications.
Subject: Re: A problem with the roof inside catching the material Mon Aug 08, 2011 9:39 am
I think I know what you mean.
When inside the Kombi, looking at the back, the bracket that attaches the hydraulic rod to the raising roof on the rhs, has taken a 'bite' out of the surround that it meets when the roof is lowered.
This has happenned on ours too when the roof was lowered and wasn't forward enough to clear the surround, we were parked on a slight slope which forced the roof slightly further back than it should have been. No holes in the roof material though as we always make sure it is tucked in and can't catch on anything sharp.
When the roof is fully closed and as far forward as it can go there is only a very small clearance (5mm ish?) so the roof only has to be out by a very small amount to 'catch'.
If the roof straps are securely fastened the roof shouldn't move when driving.
I would add a picture but Tallulah is away for the week.
