 Fuel Temperature Warning Light?
3 posters
raydavies
Fuel Temperature Warning Light? Empty
PostSubject: Fuel Temperature Warning Light?   Fuel Temperature Warning Light? EmptySat Feb 12, 2022 11:11 am
I have a Brazilian T2 Rio 2007. I have recently been getting what appeared to be an fuel temperature warning light coming up. The warning light has a fuel pump with thermometer next to it. Any ideas what it is and what needs to be done?
(I can't seen to upload a photo of it for some reason!)
PostSubject: Re: Fuel Temperature Warning Light?   Fuel Temperature Warning Light? EmptySat Feb 12, 2022 12:24 pm
That's the auxiliary(small) tank low level warning light
You need to add some petrol to the small tank on the other side to your main tank. It only holds about 1 litre so best to do it with a gerry can.
PostSubject: Re: Fuel Temperature Warning Light?   Fuel Temperature Warning Light? EmptySat Feb 12, 2022 8:05 pm
There’s no fuel temperature warning. It’s as Tallulah suggested.
Fuel Temperature Warning Light? Melogo11
PostSubject: Re: Fuel Temperature Warning Light?   Fuel Temperature Warning Light? EmptySun Feb 13, 2022 11:08 am
The reason for the thermometer symbol is that in Brazil where your kombi was built, the small tank is used to start the engine using regular petrol when the temperature is lower than say 15 degrees, while the main tank contains bio-ethanol.
Bio-ethanol is not available in the UK, so the low temp start is never an issue for us hence the small tank doesn't get used. E85 is available on some forecourts in France/Spain and our aqua buses love it, as does your wallet as it is (was) approx 1/2 the price of regular unleaded.
» Engine warning light and diagnostic mechanic needed - KT9 postcode
» Two fuel caps?
» Carbon Monoxide Warning
» Fuel duty.
» Fuel E10?
