Subject: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 10:20 am
Reference your post on keeping the forum tidy Tim, could you do some instructions on how to include a quote from a different post without including the whole topic, I haven't worked that one out yet.
Sometimes I have just wanted to point someone to a particular item without including the whole thing, but have resorted to suggesting a couple of words to search which brings up the whole topic to look through.
Apologies in advance if it is a simple solution and I am being a bit dim.
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 11:22 am
Quote :
DL - highlight the part you want to Quote, copy it, then use the speech bubble icon to paste it in.
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 11:31 am
Ok diz, here goes ... let's use your post above to demonstrate.
First of all click on the 'Quote' icon in the toolbar of the post you want to quote from:
It's the icon 1 in from the left.
This will then select all the text from the previous post with quotation start and finish coding at the beginning and end. Like this:
Now you simply delete from within that text the stuff you don't want, so let's say I only want your middle paragraph, having removed the text I don't want, I'd be left with:
I can now type my reply either above or below the content that has the quote coding at the start or finish. As long as I don't type within the quote coding, my text will remain clear. Further, if I want to include other bits of a post, I simply copy the start and end quote coding and place them around the relevant text.
Pressing Preview or Send would result in this:
Clear as mud huh?!
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 12:17 pm
Thanks Tim, got that, but perhaps I didn't explain properly what I was after.
Say someone asks about the cost of doing up a trailer for example under 'General discussion' and I wanted to reply under that topic and point them to just the one post of Tallulah's at the bottom of page 4 of 6 pages in the topic 'Maintenance/Technical - Kombi Creative' Trailer refurb project without quoting the whole 6 pages, or suggesting they use ('Trailer' in the search box facility) that's what I am having trouble with.
(I suspect I may have a 'Doh' moment coming up, )
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 12:28 pm
2 options:
1. Use the quote function on the post that Tallulah has made and then copy the whole section within the quote coding ie:
... then paste that into your reply.
Or 2. make use of the Copy BBcode URL function found at the top of the page via the Actions tab.
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 12:39 pm
Magic like this, thanks, I'm now a happy bunny, been trying to do this for ages, (Doh ) Apologies for being dim.
Tallulah wrote:
Just did some quick sums and the total spend so far is around £600 excl labour.
Trailer - £50 Misc tools - wire brush drills and grinding disk - £25 Hammerite & red oxide paint - £18 Hubs and bearings - £48 Wood for panelling - £28 Exterior wood sealer paint - £12 Exterior high gloss paint (colour match) 1l £40 - lots left Underseal - £9 Lights - £40 Bumpers - £28 Mudguards - £38 Mudflaps - £20 - bought at sleepover (4) for £40 two more to be fitted to Tallulah Wheels - £130 Tyres - £20 ea fitted. £40 Cover - £18 Misc other fittings - reflectors, secondary coupling, bungee hooks - £20 Misc other sundries - special screws, bolts, electrical connectors etc - £25 Trailer electrics cable and connectors - £9
Subject: Re: Keeping the forum tidy, posting from other posts Tue Aug 19, 2014 12:42 pm
Sweet.
