| Heater Project | |
+13tiggy23 eddy osg dazdub Baydreamer Skytiger Kev irishman TimV olive Scooby max kiteman 17 posters |
| Subject: Heater Project Mon Dec 27, 2010 4:38 pm | |
| Finally made a decent start on the heating vents. Started by building a frame to fit the ducting. Goint to have 2x80mm ducts going into two Y pieces one will do the windscreen vents, the other the side dash vents. The frame will fit over the back half of the heater. Will keep you all updated on the progress ________________________________________________________________________________ Ginger man without a ginger van | |
max
Cabin : Economy Location : London Posts : 231 Join date : 2010-10-29
| Subject: Re: Heater Project Tue Dec 28, 2010 4:32 pm | |
| Good stuff. Did you make 4 cuts into the ends of the ducts to fit them to your wooden frame? Can't wait to see more | |
| Subject: Re: Heater Project Tue Dec 28, 2010 8:20 pm | |
| Yep. Just squared the ends up and cut 4 slits to fix them to the frame.
Next bit is to fix some sort of baffle so I can get a servo to direct the air flow. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Fri Jan 07, 2011 3:16 pm | |
| Had another play in the garage today. First bit is for the side dash vents. Cut the baffle to fit in the Y piece, this is to stop the airflow if needed. Fitted the servo to the housing this will then push a lever to close the baffle. Will do the same for the dash window vents, so I will be able to have airflow to either, both or none. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Fri Jan 21, 2011 6:48 pm | |
| Well it's all gone a bit Pete Tong. Have had to go for a total design change, there's not enough room to fit the two sets of ducts as my under dash tray is in the way. Only way to do it now is to just get the front screen vents working. Got some 75mm, 80mm and 90mm ducting for sale if anybody needs some. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Wed Jan 26, 2011 7:07 pm | |
| Looking at fitting one of these
Link
Going to put an 100 - 80mm adapter then an 80mm Y piece with two 50mm ducts going to the font dash vents, will put a damper in there to control the airflow.
Might even get a couple of these
Link
to angle the airflow towards the passenger. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Fri Jan 28, 2011 1:15 pm | |
| OK here we go with Mark 2 Ended up getting the 204mm elbow bend with the 100mm connector as the width of the heater box is 160mm. Cut this down and reshaped it so it now fits over the heater box. Need to smooth it all down and paint it before it gets fitted properly. Underneath is going to go a 110mm elbow to blast hot air towards the passanger seat. ________________________________________________________________________________ Ginger man without a ginger van | |
max
| Subject: Re: Heater Project Fri Jan 28, 2011 2:08 pm | |
| Oh no! You spilled tomato sauce all over it! Looking good! Can't wait to see more. | |
| Subject: Re: Heater Project Fri Jan 28, 2011 3:36 pm | |
| That's what happens when you work trying to eat a bacon roll. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Sun Jan 30, 2011 4:59 pm | |
| Hey Kiteman Here is our approach to heat in the back - crude & simple we know - but it works for us at present! (please ignore the dust & dirt - needs a bit of clean inside - perhaps when it is warmer and the cab mat is fitted) All the best with your continued endeavours which we shall watch with interest Scooby | |
| Subject: Re: Heater Project Sun Jan 30, 2011 5:57 pm | |
| Very clever, are they seat and back heated seatpads I see | |
| Subject: Re: Heater Project Mon Jan 31, 2011 10:48 am | |
| Hi Olive Heated seat pads sounds great - sadly they are not on Scooby | |
| Subject: Re: Heater Project Mon Jan 31, 2011 10:50 am | |
| Hey Tim Maybe in due course - never say never - but other priorities at present | |
| Subject: Re: Heater Project Thu Feb 03, 2011 5:21 pm | |
| More tinkering in the garage today. Ducting for the passenger fitted now. Bit more fibreglassing to do then can fit the servos and dampers. All the funky stuff like the controller and LCD screen have turned up as well now so can start writing the code to get it all working. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Sat Feb 05, 2011 6:26 pm | |
| Another productive day. The main housing is now finished along with the round ducting that will feed the 50mm screen vent ducts. Just need to paint it black and mount the servos. The dampers are done, just need final fixing and servo arms added. The two pieces will fit together like this. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Sun Feb 06, 2011 1:21 pm | |
| Subject: Re: Heater Project Sun Feb 06, 2011 5:08 pm | |
| Thanks Irishman, should be done for the summer. Got most of the coding and the display working now. This is going to display the temperature at the top, not sure whether to have inside or outside temp at the moment. and will show what position the dampers are in. Want to fit it in the main dash console. Should be some room to the right of the speedo dial, will have a chat with Danburs to see if I can get hold of a spare to mess about with. ________________________________________________________________________________ Ginger man without a ginger van | |
max
| Subject: Re: Heater Project Mon Feb 07, 2011 7:52 pm | |
| That's just fantastic. Well done, mate! | |
Cabin : Economy Location : Hants/Berks border Posts : 249 Join date : 2010-05-10
| Subject: Re: Heater Project Mon Feb 07, 2011 8:11 pm | |
| This is really great KiteMan and thanks for the step by step updates, can’t wait for the next instalment.. ________________________________________________________________________________ 2006 Air-Cooled Duby
| Subject: Re: Heater Project Mon Feb 07, 2011 9:38 pm | |
| Mega hi-tech, great work, would never have thought of the servos.
Looking forward to seeing the finished installation.
| Subject: Re: Heater Project Fri Feb 11, 2011 5:14 pm | |
| New dash facia turned up. Got the LCD roughly fitted, just need to find a way of securing it properly and hiding the circuit board ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Sun Feb 13, 2011 4:50 pm | |
| Almost done. Here's the unit fitted to the heater. The servos are now fitted and working Just need to wire the whole thing up properly, fit the new dash facia, then it's ready to be properly installed into Ginger. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Sun Feb 13, 2011 5:58 pm | |
| looking good | |
| Subject: Re: Heater Project Sun Feb 13, 2011 6:05 pm | |
| Looking cool Kiteman What are you going to put the other side of the dash to make it balance? Scooby ________________________________________________________________________________ Proud winners of Spike's Trophy 2017 Scooby - Born To Run | |
| Subject: Re: Heater Project | |
| Heater Project | |
