| Heater Project | |
+13tiggy23 eddy osg dazdub Baydreamer Skytiger Kev irishman TimV olive Scooby max kiteman 17 posters |
max
Cabin : Economy Location : London Posts : 231 Join date : 2010-10-29
| Subject: Re: Heater Project Mon May 09, 2011 4:12 pm | |
| Good Job, Mr Kite. I concur, 0-100 is the way to go! | |
| Subject: Re: Heater Project Wed May 18, 2011 5:20 pm | |
| The speed controller turned up the other day. Had a little look to try and get it to work with the original switch but to no avail. The rotary potentiometer that is used to control the motor speed is too small for the hole originally drilled into the dashboard, so I've got one of THESE from ebay. Will have a go at fitting it tomorrow and let you know how I got on. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Thu May 19, 2011 3:47 pm | |
| The variable speed switch is now fitted Used one of THESE. can't seem to find any in the UK. stuck that next to the heater box. For the power I pulled the connector off the back of the dash switch. The Orange wire is the earth and the red wire is the mains from the ignition. Just cut off the plug and crimped the ends to get the power down to the heater plug using the exisiting loom. That gave me the mains power into the controller. The power to the fan used the other end of the plug that goes to the heater fan. When looking at the plug, the black wire is the earth and the blue wire the one for full speed, the red is for half speed. Connected the yellow from the controller to the earth and the white to the blue full speed. Soldered the new rotary dial, as shown in the previous post, to a longer cable to reach the dash. Had to file the flat part of the dial stem to get the original knob to fit. then fixed it to the dash. Now have 0 - 100% speed. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Thu May 19, 2011 4:25 pm | |
| You are the kiddie kiteman! ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Heater Project Thu May 19, 2011 4:57 pm | |
| Well done Kiteman You can now also control fan noise levels as well? ________________________________________________________________________________ Proud winners of Spike's Trophy 2017 Scooby - Born To Run | |
Guest Guest
| Subject: Re: Heater Project Thu May 19, 2011 10:07 pm | |
| you beat me to it young kiteman !!!!! glad to see you have it working ,will keep you posted on mine. |
| Subject: Re: Heater Project Wed Sep 28, 2011 10:19 am | |
| Hi Kiteman just fitting the variable speed unit just one question did you use the old heater switch to turn power on/off or do you just turn it down to zero. Thanks Tim
PS good to meet you at vanfest | |
| Subject: Re: Heater Project Sat Oct 01, 2011 5:40 pm | |
| I just turn the dial down to zero, seems to do the trick. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Mon Jan 16, 2012 6:00 pm | |
| Been having a bit of a mess around with my heating system again. As people who have seen my project will know the selector switch didn't work as well as I wanted it to. I have been playing with a touch screen and seem to have got it working The touch screen is from a mobile phone which I got of ebay for £2 Had to change the display as the touch screen is smaller than the LCD. The 'O's being vent open and the '-'s vent closed The idea will now be. If I want to open or close any of the vents all I need to do is touch the word of the vent I want to open or close. It's working on the bench, all I need to do is try and connect it to the system. Then make a new bezel for the LCD screen to tidy it all up ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Mon Jan 16, 2012 6:24 pm | |
| Looking good You must have it fully operational for Volksworld ________________________________________________________________________________ Proud winners of Spike's Trophy 2017 Scooby - Born To Run | |
| Subject: Re: Heater Project Mon Jan 16, 2012 7:00 pm | |
| I am constantly amazed and impressed by your development of the Kiteman Air Transportation System. Looking forward to your next installment ________________________________________________________________________________ Matt. | |
| Subject: Re: Heater Project Mon Jan 16, 2012 10:25 pm | |
| Kiteman Brilliant (as usual) Is there a failsafe which prevents all flaps closed at the same time - to save the fan from blocked air flow? osg | |
| Subject: Re: Heater Project Mon Jan 16, 2012 10:41 pm | |
| The heater box is split into 3 sections. The top half goes to the screen vents, the lower left is ducted to the passenger seat and the lower right is open and blows air to the driver. Even if all the flaps are closed the air will still go towards the driver. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Tue Jan 17, 2012 9:12 am | |
| Kiteman said "The heater box is split into 3 sections. The top half goes to the screen vents, the lower left is ducted to the passenger seat and the lower right is open and blows air to the driver."
So air to the driver has no flap and is always open. I'm now still a bit confused as to which 3 flaps connect to your 3 control commands of 'Left', 'Front' and 'Screen' osg | |
| Subject: Re: Heater Project Tue Jan 17, 2012 9:15 am | |
| Left goes to the passenger.
Screen is for the windscreen.
Front is for the Air vents at the front that used to be rivited shut for the RHD conversion. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Tue Jan 17, 2012 9:32 am | |
| Front - round vents that point at the side windows? ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: Heater Project Tue Jan 17, 2012 12:51 pm | |
| The front ventilation flaps behind the front grill, just below the front screen, between the indicators. They open to let fresh air in now. Get a lovelly cool breeze on the legs in the summer. See Herefor original modification ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Tue Jan 17, 2012 1:40 pm | |
| AHA! So not 'technically' connected to the heater at all. Now that's a feature I would definitely like to have. ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: Heater Project Tue Jan 17, 2012 4:30 pm | |
| Subject: Re: Heater Project Tue Jan 17, 2012 4:55 pm | |
| The front vents are normally ducted to the front screen and the vents at the end of the dash. These used to be removed by Danbury when they were converted to RHD as the steering column and dash are in the way. The front flaps are then riveted shut. On LHD kombis everything is still in place. The void is left empty. The black stuff you can see is the foam seal used on the back of the flaps to help seal them when they'r closed. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Tue Jan 17, 2012 5:14 pm | |
| Subject: Re: Heater Project Thu Jan 19, 2012 1:12 pm | |
| Have it installed back in Ginger again and works a treat. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project Thu Jan 19, 2012 3:16 pm | |
| Electric pop-top. ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Heater Project Thu Jan 19, 2012 4:18 pm | |
| Been looking into it but think it might be more hastle than it's worth ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Heater Project | |
| Heater Project | |
