 Rear brakes adjust clean
2 posters
Rear brakes adjust clean  Empty
PostSubject: Rear brakes adjust clean    Rear brakes adjust clean  EmptyThu Jun 02, 2011 8:15 pm
Hi have just cleaned and adjusted my rear brakes this is how I did it first crack wheel nuts then jack up bay and put axel stand under and place wadge under front wheels and take wheel off then back adjusters off so drum can be take off see picRear brakes adjust clean  11b6a505 this is were adjusters are under gromets pull them off Rear brakes adjust clean  025f3a6a now using a flat blade screwdriver spin both adjuster lose now drum will come off don't hit with hammer on edge just a very soft hit in face between studs and wiggle drum off now drum is off check brake linings are ok Rear brakes adjust clean  7c0ef660 and wheel cylinders are ok and not leaking pull both rubber covers back see if they are dry like mine if so all okRear brakes adjust clean  11e90136 next thing clean and grease adjuster Rear brakes adjust clean  401b65b4 they just pull out clean them and copper grease them and put them back inRear brakes adjust clean  9cbc076cRear brakes adjust clean  8aa46fd1 now clean all the brakes and all parts with brake spray use a small amount of wd40 on springs and cable and refit drum put some copper grease on studs and re fit wheel now pump up pedal to line up shoes and re adjust back up adjust till they catch than back off so they are both free same on both sides then tighten up nuts and away you go
Bob
Bob
PostSubject: Re: Rear brakes adjust clean    Rear brakes adjust clean  EmptySun Jul 06, 2014 11:05 am
I carried this out yesterday after i found that the RH drivers side would bind after i had adjusted and operated the hand brake. However, the problem persists.
The LH passenger side behaves how i would expect but the drivers RH side still binds after adjustment.
After backing off the adjusters to release the brake, i operate the handbrake and release it but the brake binds again. In the end I gave up and took the van for a spin and everything appears ok.
I'm not convinced I've got the best brake adjustment though. I suspect the cable is binding in the tube somewhere and guess replacing it is the best option.
Any thoughts?
PostSubject: Re: Rear brakes adjust clean    Rear brakes adjust clean  EmptySun Jul 06, 2014 12:16 pm
Any thoughts?
try and spray cable as it might seized
» Front brakes clean
» bunting in rear window - how to?
» Scooby Clean for Halloween!
» rust on rear arch
» Danbury discount on Rear Spare Wheel Carrier
