 Gear stick advice
4 posters
LesleyH
Gear stick advice  Empty
PostSubject: Gear stick advice    Gear stick advice  EmptyMon Nov 18, 2024 5:33 pm
Hello,
I've been advised that I need a new gear stick by the mechanic who looks after my van. This will be the second time I've had to replace it and would like to know what types are suitable. The only advice I was given was 'buy a good one'!!
HELP
Lesley
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyMon Nov 18, 2024 8:10 pm
The CSP gear stick is the best one in my opinion. Not cheap but so much bettter
LesleyH likes this post
LesleyH
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyMon Nov 18, 2024 11:57 pm
Is that what you have? I looked at one on Heritage Parts Centre, but they said it wasn't compatible! Can you tell me the specific one?
TomW
TomW
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyYesterday at 10:38 am
This is the one I installed on my RHD bus:
https://www.heritagepartscentre.com/uk/ac711123r-csp-straight-t-handle-gear-shifter-for-right-hand-drive.html
LesleyH
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyYesterday at 10:51 am
Thanks so much. I'll get on to them about this one
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyYesterday at 3:23 pm
Yes I have the csp one. Had the original. Changed to the empi one. Then changed to the csp one.
The one Tomw had highlighted is the one I have but mine is a left hand drive.
So much better gear change
LesleyH
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyYesterday at 5:31 pm
I was speaking to someone today about this one and he said he found it to be quite narrow and stiff. Do you find that?
PostSubject: Re: Gear stick advice    Gear stick advice  EmptyYesterday at 7:58 pm
Fitted mine 12 years ago it will transform your gear changes.
Gear stick advice
» new gear shift stick
» refitting gear stick
» Wanted oil temp dip stick
» '68 Bay on the Top Gear Track
» Brazil's Top Gear. NOT!!
