 Extra 12v Power Sockets
belgiumbay
8 posters
Extra 12v Power Sockets Empty
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Jun 14, 2011 7:53 am
Excellent work Bruce. Thanks for the photo guide. Basketball
Extra 12v Power Sockets Melogo11
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Jun 14, 2011 8:37 am
Good work. Like the idea of the vertical sockets as well, nothings going to fall out of them. alien
Extra 12v Power Sockets Img_4810
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Jun 14, 2011 5:54 pm
Nice one peppa and I like the nod to 'marine' seeing that you have an AquaBay.
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Jun 14, 2011 6:22 pm
Do you shout 'coming about' when you turn corners?
belgiumbay
belgiumbay
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Jun 15, 2011 7:28 am
We fitted a 12v socket under the RnR can just see it in the corner of the pic, can also see the French sockets we have fitted into the wardrobe unit as well as the mirror I had to fit to hide the hole that was there from the original UK socket was fitted so low you couldnt actually plug anything into it secodn picture shows the beautiful euro socket better - much cleaner lines than Uk ones. But the big project for the summer is fitting an ipad 2 as a head unit for a rear amp and speakers. will most likely fit it using the griffin cupboard mount
Extra 12v Power Sockets Image-10
Extra 12v Power Sockets Plug10
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Jun 15, 2011 11:09 pm
Excellent job, really like the look of those sockets Tilly.
Matt.
Extra 12v Power Sockets Img_2014
valentine29
valentine29
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Jul 12, 2011 2:52 pm
Hi, does anyone know which fuse powers the plug sockets? I have four plug sockets inside the camper and none of them work! I have never used them before and am just in the process of testing everything before we make our debut trip to Cornwall next week. I have located the fuses under the dash but i'm assuming these are for the indicators etc. There is a main power box in the wardrobe area at the back of the camper. Help!! I have no idea where to start solving this problem. Mine is the old type brazilian, 02 plate. Many thanks.
http://info@imaginephotographystudio.com
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Jul 13, 2011 11:14 pm
Valentine, the sockets only work when you are connected up to an electric hook-up on a campsite.
Matt.
valentine29
valentine29
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyThu Jul 14, 2011 9:05 am
Oh thanks so much, this is first time i've taken the camper to a campsite, what a relief!
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Nov 29, 2011 8:30 pm
Glad I found this great 'how to' Tilly. I've had the same trouble with the front cigarette lighter socket as others have elsewhere, and have been toying with fitting a couple of sockets connected to the leisure battery. Not only for similar reasons to yours, but being a 'belt and braces' type, my thinking was that if ever I got a flat battery away from home, I could use one of those 'plug and go' type jump cables that go between cigarette lighters from the donor car to the car with the flat, only in this case the donor would be the leisure battery. Not having used one of these types of leads before, my question is, do they work, and is this plan feasible? Smile
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Nov 29, 2011 10:02 pm
I think the theory is that you leave the two batteries connected for about 15 minutes, and enough power is transferred from the donor to the main battery to give it enough umph to turn the engine on its own, but not having tried one , I'm not sure. There must be something in line that drops the current right down I presume.
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyMon Dec 05, 2011 7:08 pm
Thanks for that, Tilly. That was the thing I was thinking of, I could see you concern over the melting problem, I've managed to melt cheap jump leads before as well! Smile
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyMon Dec 12, 2011 5:44 pm
Had a look at one of those plug and go leads in Maplins last week, it appears that the donor vehicle has to have the engine running and lead plugged in before connecting to recipient, so presumably no good running off leisure battery! Worth a try, but I think I'll forget this one! Sad
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptySun Sep 08, 2019 11:02 pm
Hi - this is the very hot-to I've been looking for - but it seems not to be there - can anyone point me in the right direction for the how to install additional 12v sockets pls. Thanks :-)
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptySun Sep 08, 2019 11:36 pm
Sorry - the OP left us a long time back and deleted his account. By doing so that caused all of his posts to be deleted. Basketball
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyMon Sep 09, 2019 10:30 am
I installed a 12v (cigarette lighter) socket at the rear which we use for charging phones etc overnight, also a twin usb socket above the battery meter on the kick panel below the rear seat.
The install was quite straight forward, the 12v socket is attached with two self taping screws, I drilled a small hole in the gas cupboard (Rio layout) for the cable to go through and ran it down inside past the sealed gas compartment and out underneath next to the leisure battery.
The usb socket is set into the kick board so I drilled a large whole the correct size to fit that.
The two sockets were then wired directly to the leisure battery with separate 10A inline fuses. All of the connections were soldered and I soldered spade connectors onto the wires to connect to the battery.
If I get a chance I will take some pictures and add them to the post, but Tallulah is fully loaded at the moment.
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyMon Sep 09, 2019 11:05 am
That's really helpful, thanks - I'm also toying with replacing the battery meter with something a bit more accurate cos I find the original one a bit vague and I thought of adding a panel with 12v sockets and a voltmeter. :-)
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyTue Sep 10, 2019 11:52 pm
Tallulah, you've been very helpful and sorry to bombard you with more questions but my ambition is not matched by my ability so your advice is really appreciated. I've bought a voltmeter which I'm planning to replace the Danbury battery meter with. When I'm on the ehu will that blow the volt meter (6v-30v) or does it step the power down? I'm planning to connect a new USB to the battery the way you suggested too. Thanks in advance
Pete
Sent from Topic'it App
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Sep 11, 2019 8:53 am
The standard Danbury installed meter is just a 12 volt item.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F201400210112
Replacing it with a unit that has a gauge should be no problem.
fat_pastor
fat_pastor
Cabin : Exec
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Sep 11, 2019 9:57 am
Thanks Tim, that's really helpful.
PostSubject: Re: Extra 12v Power Sockets   Extra 12v Power Sockets EmptyWed Sep 11, 2019 9:59 am
CBE even do a voltmeter which sits in exactly the same aperture:
CBE voltmeter
» Extra Seat
» What did you doo with that extra hour?
» An Extra Day Tomorrow
» What did you Doo with your extra hour this morning?
» Kombikabins - get an extra room for your BraziBay for $249
