You need to make the "About Absinthe" widget (lower right) wider so that it fills the rh column in the same way as the "Blog Archive" one does above it.
I'm guessing the home page is set to display all blogs from the current month which makes it quite long, might be useful to change this (if possible) to display only the latest one.
I also noticed that a couple of the pics aren't centred, but aside from that I think it looks great.
The "about absinthe" widget appears to be laid out within a 2 column table, each column being allocated 50% of the available width even though there is nothing in the first column.
That may or may not help you at all, but there might be some settings for that particular widget that you can change.
Looks nice but imho I'm not keen on having the whole post taking up the main page. I prefer linking to the bulk of the post on another page, with maybe a little teaser paragraph on the main page. I can see the Archive list on the right but its not the same.
Wed Jul 17, 2013 12:20 pm by Tallulah
