| KOMBI Kaper 2015 | |
+27Skytiger Scooby kiteman MrsHH dizzylizard Voyager Dickymint1972 AbsintheKombi beakyboy Happyhouse Dennis dazdub TimV URmysunshine sundialsoft MarcusH irishman Tallulah harryhornet jill jaredtiller MrsTallulah Baylee timmm gordonmac RayC Sunny 31 posters |
What's the Kaper 2015 to be? | 2 weeks on the Ile de Re? | | 89% | [ 8 ] | 1 week on the Ile de Re then 1 week somewhere North? | | 11% | [ 1 ] |
| Total Votes : 9 | | Poll closed |
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:03 pm | |
| If the wheel is broken how do you turn the gas on and off. Tim | |
Cabin : Flight 044 Location : Alderley Edge Posts : 1374 Join date : 2013-08-10
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:11 pm | |
| - Dennis wrote:
- If the wheel is broken how do you turn the gas on and off. Tim
There's a tap next to the regulator, but the regulator is attached to the bottle by a hose rather than being mounted on the bottle. There is a small nut on top of the bottle where it looks like the wheel used to be. I could screw that down with a small spanner, but as I said, I don't really want to tinker about with it. | |
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:20 pm | |
| - alderley wrote:
- I just noticed that they only allow gas or electric barbecues on the pitches, but that there are some communal barbecues. Will it be a waste of time to take the Cobb?
I'm still going to take the 'Prakti'. It is a stove, not a BBQ and nothing a wind break can't hide! | |
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:25 pm | |
| - alderley wrote:
There's a tap next to the regulator, but the regulator is attached to the bottle by a hose rather than being mounted on the bottle. There is a small nut on top of the bottle where it looks like the wheel used to be. I could screw that down with a small spanner, but as I said, I don't really want to tinker about with it. Fully clockwise is off so if you screw it fully down you can carefully release the hose connection and there should only be a very small hiss as the gas in the tube escapes. More than a small his and do the hose nut up again to stop it. Note these are gas fitting so they are reverse threaded. This looks like a replacement one: GOK 310/801-1 Gas Bottle Valve ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:37 pm | |
| This is what my gas bottle looks like: The broken wheel is a Gok as Tallulah suggests. From Tallulah's advice it seems that I just need to use a small spanner to screw down the small nut, and then I can presumably remove the valve so that the bottle can be exchanged. Having said that, I think that 1.1kg of gas should last us the 2 weeks, as long as I take the Cobb and a supply of briquettes. | |
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 1:56 pm | |
| Yes, if you know that the valve is currently fully open then it will only turn one way - clockwise.
Once the valve is closed, the gas hose can be undone and the bottle lifted out.
The valve will then unscrew from the top of the bottle so it can be screwed onto a new one and the new bottle with valve can be lowered back into the box. Reconnect the hose, open up the valve and you're good to go.
I highly recommend you buying a new valve or at least replace broken wheel so that you can turn the gas off fully while not in use, especially when driving. In the event of an accident you really don't want a gas bottle with an open vavle hanging around! ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 2:32 pm | |
| I've now closed the valve using a small socket which I'll keep in the van until I get a new wheel. It looks as if the hex nut is only intended to secure the wheel to the squared-off shaft of the valve, but it seems to work fine for opening and closing the valve. | |
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 2:40 pm | |
| Last year there was gas bottle refills in the local super market (Super U) so while refills might not be available on the site, there will surely be somewhere close by. ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: KOMBI Kaper 2015 Fri Jul 10, 2015 6:48 pm | |
| 2 weeks tonight! ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: KOMBI Kaper 2015 Sat Jul 11, 2015 7:01 pm | |
| I could supply some insurance certs... ________________________________________________________________________________ Absinthe makes the heart grow fonder
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 10:58 am | |
| Looking back on the pictures from last year's Kaper I noticed that there was a distinctively French feel to the outfits worn at the meet up in Portsmouth. Do we need to look out for some blue and white stripey t shirts and berets? | |
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 11:24 am | |
| I'll be dressed as Napoleon... ________________________________________________________________________________ Absinthe makes the heart grow fonder
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 11:33 am | |
| - AbsintheKombi wrote:
- I'll be dressed as Napoleon...
A BraziBay Revolution. | |
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 11:43 am | |
| No Wellingtons please... ________________________________________________________________________________ Absinthe makes the heart grow fonder
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 1:45 pm | |
| Just read this in the paper today, not likely to happen, but worth bearing in mind.
http://www.telegraph.co.uk/news/worldnews/europe/france/11733790/Bogus-French-police-stopping-cars-to-rob-tourists.html | |
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 3:34 pm | |
| About that, "we only need a small pitch" thing. Mrs B has decided that we should take the Glawning for storage purpose. I suspect she has a plan for me to sleep in there so she doesn't have to wear ear defenders at night.
I think we'll have it freestanding, not attached to the van though. Getting excited now. I'll be list making tomorrow... ________________________________________________________________________________ Absinthe makes the heart grow fonder
Cabin : Exec 007 Location : New Forest, Hampshire Posts : 256 Join date : 2011-10-02
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 8:11 pm | |
| Kombi kaper camp is going to look great at least 3 bell tents and a glawning | |
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 8:15 pm | |
| - Happyhouse wrote:
- Kombi kaper camp is going to look great at least 3 bell tents and a glawning
Not mention all the kolourful kombis! ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 8:16 pm | |
| and lights and flags ☀️☀️☀️☀️ | |
URmysunshine
Cabin : Exec 043 Location : Norfolk Posts : 374 Join date : 2013-10-07
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 8:50 pm | |
| Subject: Re: KOMBI Kaper 2015 Sun Jul 12, 2015 10:03 pm | |
| .....and astro turf! | |
| Subject: Re: KOMBI Kaper 2015 Mon Jul 13, 2015 11:02 am | |
| Just reading through the activities available on-site, and I note 'table tennis' so will be bringing our bats along. Anyone else a budding ping pong player? ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: KOMBI Kaper 2015 Mon Jul 13, 2015 11:27 am | |
| I used to play a bit, but not for quite a while now. Oli likes a game of Ping Pong.
Last year we brought along our collapsible badminton set (could also be a vollyball net) which was barely used - shall I bring it this year? ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: KOMBI Kaper 2015 | |
