| Front Air Vent | |
| Subject: Front Air Vent Tue Jun 01, 2010 2:49 pm | |
| Do any of you guys have a working front air vent. Mine's riveted closed due to the RHD convertion. Thinking of fitting a couple of servos to the flaps to get them operational again, will also be part of my HNC project for next year. My question is, how far do the flaps lift. Do they go all the way up, or stop when horizontal?
will keep the post running with my progress | |
| Subject: Re: Front Air Vent Tue Jun 01, 2010 4:43 pm | |
| I can't remember Steve - only checked my flaps when I colour coded the grille and resealed around them - a year ago now. It would be great to get them functioning again to get more airflow into the cabin. There must be some bits you can pinch off one of those old 757s they've got hanging around the back of LHR! ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
Cabin : Economy Location : Hants/Berks border Posts : 249 Join date : 2010-05-10
| Subject: Re: Front Air Vent Tue Jun 01, 2010 6:29 pm | |
| I would also like to free the air vent flaps on my bus too, was pretty stuffy driving over to the Just Kampers day in the heat, which prompted a similar conversation with Tim. Does anyone know why they were sealed down, is it purley as the lever is disconnected (maybe they rattle about with no lever?) or is there a another reason? Jason anyone at Danbury shed any light on this? Cheers K. ________________________________________________________________________________ 2006 Air-Cooled Duby
| Subject: Re: Front Air Vent Tue Jun 01, 2010 6:31 pm | |
| - Kev wrote:
- (maybe they rattle about with no lever?)
They don't rattle about as they're either screwed or rivetted into the closed position. They are of course a major point of water ingress to the front panel ..... that may have something to do with it. ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Front Air Vent Thu Jun 03, 2010 1:19 pm | |
| Progress so far. Have built a scale mock up and got flaps to open and close, just need to fit it to the van now. To control the servos I've used a small micro controller which has been programmed to operate the servos on a switch. picaxe controller When the switch is on the flaps will open and vice versa. It all runs on 5v so I've had used a voltage regulator to step down the 12v coming from the van. Going to run a servo on each flap. | |
| Subject: Re: Front Air Vent Thu Jun 03, 2010 3:22 pm | |
| You are Joe 90 kiteman. ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Front Air Vent Sun Jun 06, 2010 4:24 pm | |
| Wow, your officially Mr technical ________________________________________________________________________________ Matt. | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 10:51 am | |
| ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 10:55 am | |
| Wow - good job kiteman!! ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 4:29 pm | |
| All finished The electronics I've used a picaxe 08M proto board to control the servos. Had to programme the chip with a simple code. Putting it simply 'If switch is on the move the servos down. If switch is off move servos up'. Fitted the servos as shown above. Put a switch in the dash Then wired it up. Servos and controller have to come off different regulators to stop any interference. Tested it out and it works a treat. Just need the weather to warm up again to see how good it works ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 5:34 pm | |
| Fab! ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 5:56 pm | |
| Looks like you might have a little side line business starting shortly steve, how much did the parts cost you? ________________________________________________________________________________ Matt. | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 6:01 pm | |
| Thats a really nice job Kiteman ________________________________________________________________________________ 2006 Air-Cooled Duby
| Subject: Re: Front Air Vent Thu Jun 10, 2010 6:23 pm | |
| - Matt wrote:
- Looks like you might have a little side line business starting shortly steve, how much did the parts cost you?
The controls were the cheapest bit. £8 thats including the switch, box and microcontroller. Voltage regulators were £10 each. Can do this a lot cheaper, but the cheaper ones get very hot. The servos are about £20 each. Had some knocking around already, thats why I chose to do it that way. Then about another £5 on extras like servo linkages, fuse holder, gromits and stuff. Get a bit of a buzz coming from the servos but it soon disappears when the enine is running ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Front Air Vent Thu Jun 10, 2010 6:25 pm | |
| - TimV wrote:
- Can you start planning how you're going to make my raising roof electrically operated now please???!!! Naturally using your own Bay as a test bed so you've perfected the procedure by the time you get to mine
I'll have it all done remotely for you. Hot Tub as well ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Front Air Vent Wed Jun 16, 2010 11:29 am | |
| Hi Guys - Danbury have not connected the air vent system before as we cant get hold of the RHD air flow parts to do the job. We are looking into it now though for all 2011 models (yes were working on next years model already!) and will advise you of any changes. All the best - Jason. www.danburymotorcaravans.com | |
| Subject: Re: Front Air Vent Wed Jun 16, 2010 12:36 pm | |
| Hi Jason, Thanks for the reply on this, its good to know the background. Looks like we need to get our orders in to Kiteman!!!! Cheers K. ________________________________________________________________________________ 2006 Air-Cooled Duby
| Subject: Re: Front Air Vent Thu Jun 17, 2010 4:12 pm | |
| Cheers Den thanks for the kind words matey. Managed to test them out properly today and they work a treat, lovelly cool air blowing on the legs Been having a bit of a think after meeting Denni If people are interested I could probably come up with a DIY version. I'd get all the bits you need, build the circuit board and program the chip etc, all you would have to do is fit it to the van. I can put up a more detailed instal if people want me to, to give you a propper idea on what exactly needs to be done. Drop me a PM or reply to this thread if your interested and I'll have a bit of a play over the next few days, see if I can come up with an improved mk2 version and see how much it will cost. ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: Front Air Vent | |
| Front Air Vent | |
