| rust on rear arch | |
+15haum Roobarb Scooby Dennis Skytiger kiteman michel_bonn pastymaster dizzylizard Sunny Tallulah chairboy_paul TimV osg dazdub 19 posters |
| Subject: Re: rust on rear arch Tue Jun 12, 2012 8:04 pm | |
| and all of this because no cavertey rust prevention and my bay did have Danbury anti corrosion under body protection from new so please all you Brazilian bayers get your bay done my bay has only done 48k from new wax oyl wax oyl wax oyl | |
| Subject: Re: rust on rear arch Tue Jun 12, 2012 8:18 pm | |
| Daz Sorry to see your rust there. But it looks like you will fix it.
Your final picture does show some manufacturer's holes in the inner wing which can be used to squirt in Waxoyl or Dinitrol. These should be found even under any underseal. Mine were covered with tape beneath the underseal - but may be sealed with grommets instead. Seems a good idea to check these holes are covered with tape or grommets to prevent water ingress.
osg | |
| Subject: Re: rust on rear arch Tue Jun 12, 2012 8:26 pm | |
| - osg wrote:
- Daz
osg thanks didn't think it would be that bad but rust is always worse than you first think. and yes there are a lot of grommets all over body I did wax oyl my bay but it had rust when I got it so it was to late to stop it but I am getting there now have got arch Back on now will add more pics | |
| Subject: Re: rust on rear arch Tue Jun 12, 2012 9:04 pm | |
| Take heed of this folks. The more cavity protection you give your BraziBay the less likely this will happen. ________________________________________________________________________________ Max SportsKombi - The Bay Racer @brazilianvwbay | |
chairboy_paul
Cabin : Economy Location : Reading, Berks Posts : 178 Join date : 2010-05-20
| Subject: Re: rust on rear arch Tue Jun 12, 2012 10:17 pm | |
| I have a couple of tiny bubble on both my rear arches also... telltale inside out rot. whats the best way to get between the skins to at least get some wax oyl going to stop the rot?? Cheers Paul | |
| Subject: Re: rust on rear arch Tue Jun 12, 2012 10:25 pm | |
| - chairboy_paul wrote:
- I have a couple of tiny bubble on both my rear arches also... telltale inside out rot. whats the best way to get between the skins to at least get some wax oyl going to stop the rot?? Cheers Paul
in the pics you can see 4 holes they are covered in black tape you can fill them with wax oly | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 7:01 pm | |
| Nice job. ________________________________________________________________________________ www.alpinegrovetouringpark.com Twitter: @AlpineGrove Facebook: facebook.com/alpinegrovetouringpark
| Subject: Re: rust on rear arch Wed Jun 13, 2012 7:10 pm | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:19 pm | |
| thanks all | |
Cabin : Club Location : Crewe, Cheshire Posts : 584 Join date : 2011-04-23
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:32 pm | |
| Just because I've no idea, how do you stick the arch back on? Is it all welding under the "whitish" paint. What do you do, tack weld it in place and then fill-in weld around the edge, finishing with a disk to polish before paint? (I've never done anything bodywork; it terrifies me. Part of the reason I bought new.) | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:39 pm | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:48 pm | |
| oh men, f..... i had the same problem as you have. on my car was it the other side. i have done the sam as you, mak a new on and painted it new. it is a never ending working on the car. ;-) i wish you all the best and less rust for the rest ________________________________________________________________________________ http://www.t2-c.de
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:49 pm | |
| - Sunny wrote:
- Just because I've no idea, how do you stick the arch back on? Is it all welding under the "whitish" paint. What do you do, tack weld it in place and then fill-in weld around the edge, finishing with a disk to polish before paint? (I've never done anything bodywork; it terrifies me. Part of the reason I bought new.)
spot welds takes a long time you need to move places so not to distort panel lots and lots of spot weld almost all way round then grind down spot welds paint with zinc paint then fill and sand fill and sand and a bit more fill and sand then paint in 2k high build primer and sand and repaint then wet flat and paint in top coat | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:50 pm | |
| - michel_bonn wrote:
- oh men, f..... i had the same problem as you have. on my car was it the other side. i have done the sam as you, mak a new on and painted it new. it is a never ending working on the car. ;-) i wish you all the best and less rust for the rest
thanks | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:51 pm | |
I had to do both sides :0 | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 8:56 pm | |
| not as bad on this side but still needed a new arch | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 9:47 pm | |
| Not that I would ever attempt it, but I'm interested to know, from the catalogue pictures the repair panels appear to stretch to the seam on the next panel.
Did you cut yours to fit, and did you have to have to set the edges back under the remaining panel to get a flush fit for welding? ________________________________________________________________________________ Growing old is mandatory Growing up is optional | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 10:00 pm | |
| - dizzylizard wrote:
- Not that I would ever attempt it, but I'm interested to know, from the catalogue pictures the repair panels appear to stretch to the seam on the next panel.
Did you cut yours to fit, and did you have to have to set the edges back under the remaining panel to get a flush fit for welding? I cut back till I had good metal and cut new panel just over than placed it over and marked round it and cut out on mark then butted it up and welded round the edge | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 10:01 pm | |
| You've painted it the wrong colour ________________________________________________________________________________ Ginger man without a ginger van | |
| Subject: Re: rust on rear arch Wed Jun 13, 2012 10:10 pm | |
| Excellent job Dazdub, will you have it painted for the Sleepover or are you going for the patina look I presume your using a compressor and spraygun or is it rattle cans | |
| Subject: Re: rust on rear arch | |
