 Awning Gutter Attachment Poles
3 posters
Tony880
Tony880
Awning Gutter Attachment Poles Empty
PostSubject: Awning Gutter Attachment Poles   Awning Gutter Attachment Poles EmptyMon Aug 25, 2014 4:06 pm
Hi Guys
I'm using the 4 section poles to attach my outdoor revolution oxygen 2 awning.
My current solution is to fold over the beading strip of the awning and trap it down with the awning pole. This means I can only use two clamps, causing the pole to 'bow' upwards in the middle. Is there a better solution so that I can use the third clamp?
My alternative would be to similarly 'trap' the web strap that comes with a figure 8 fixing kit and then just use the 3 sections of figure 8 to feed in the awning strip.
Any better suggestions appreciated.
Tony880
PostSubject: Re: Awning Gutter Attachment Poles   Awning Gutter Attachment Poles EmptyMon Aug 25, 2014 6:21 pm
Have you tried wrapping the beading strip over the top of the pole, around the back and then underneath. Youmcan then clamp the pole to the gutter from underneath the beading strip
Awning Gutter Attachment Poles Img_4810
Tony880
Tony880
PostSubject: Re: Awning Gutter Attachment Poles   Awning Gutter Attachment Poles EmptyMon Aug 25, 2014 6:51 pm
Thanks Kiteman. Yes I have recently tried that too and it seems to work if I make sure the wing nut is underneath the clamp rather than on top (could tear through when stormy etc)
Cheers for boosting my confidence a liitle .
Tony
PostSubject: Re: Awning Gutter Attachment Poles   Awning Gutter Attachment Poles EmptyMon Aug 25, 2014 8:58 pm
Are you sure there isn't a sleeve to slide the pole through?
Tony880
Tony880
PostSubject: Re: Awning Gutter Attachment Poles   Awning Gutter Attachment Poles EmptyTue Aug 26, 2014 8:53 am
Thanks Tallulah. I'll have a look when the rain stops lol.
We have a saying over here. When you cant see the hills its raining. When you can see them its going to rain lol.
Tony
» Best Awning
» Awning
» Flag poles
» Gutter Bulk Strip
» Awning
brazilianvwbay.com :: KOMBI Katalogue :: Bay Related Products :: Awnings/Sun Canopies-
